Results 31 to 37 of 37
28th Oct 2018, 08:29 PM #31Most Valued Member
- Australia east coast
- 2,722
A new 2MT ER25 collet chuck is maybe $40, I bought one the other week. Cut the thing off, fully support the spindle then smack the drawbar cushioned with brass etc as described already with a BFH. If it doesn't move, drill out some of the centre of the 2MT stub and do it again. Sooner or later it WILL move.
PDW
28th Oct 2018, 09:11 PM #32Most Valued Member
- Oct 2007
- 3,112
I wouldn't hold it in a vice, it will shrink the spindle and defeat the purpose. The spindle has a step and use that instead.
I can't imaging MAPP would damage the spindle, it either gets hot or it doesn't.
28th Oct 2018, 10:35 PM #33Member
- Apr 2018
28th Oct 2018, 10:39 PM #34Member
- Apr 2018
28th Oct 2018, 10:42 PM #35Member
- Apr 2018
I am yet to try MAPP gas. How should I hold the spindle so it is safe to do so (thick leather gloves might not be enough?)? I previously put the spindle into the lathe and turned at a slow speed apply the heat more uniformly but that probably dissipates the heat too quickly.
29th Oct 2018, 02:37 AM #36
Hi Mlo18,
The trick is to apply continuous pressure in a direction that will remove the chuck and then apply as much heat as you can as quickly as you can to the area where the chuck is held. The idea is to cause the shaft to expand before the chuck shaft has started to. Some one mentioned freeze spray, that would be a good idea as well. But it would need to be used in conjunction with the above. Also if the spindle can be held solidly at the same time, you could also pre-load the spindle bore so that you can give it a thump from the back as well.
Though I'm starting to think that if its that solid, machining it out could be the last resort. If non of that works then, yes it could be a new spindle time.Best Regards:
29th Oct 2018, 11:41 AM #37Most Valued Member
- Oct 2007
- 3,112
A new spindle! Holy cow, I don't think so. This is a very common thing to happen, and unless it's been stored at the bottom of the Dead Sea for the past 30 years, the tapers will unlock when sufficient force is applied. How much is "sufficient", that's the big question, but this is only an MT2 taper so it's not going to be crazy amounts.
When mentioning how to hold it etc I do think you're over thinking some of this, just make up some form of register so the spindle can stand vertically and be registered on the bearing step. If you have a lathe you can bore and weld a perfect jig for this. Heat the spindle as quickly as you can. If you have a MAPP torch and a propane torch, put both of them just up from the end of the spindle and heat it as fast as possible. While temperature helps, it's the difference in temperature that's more important. I wouldn't waste my money on freeze spray as I've found it just doesn't absorb enough heat. I'd be more inclined to drop the whole lot in a chest freezer before you started working on it. I've done that when shrinking components on and it works well, one goes in the freezer, the other goes in the oven and away you go. Whatever you do you need to work fast.
Stand the spindle in your jig and smack the crap out of the loosened drawbar. If it doesn't release use a bigger hammer. I have a fitting that goes on the end of a jackhammer for driving star pickets and I might try that, but probably wouldn't bother and would just use a club hammer first time, if that didn't release it then use a sledge hammer. Don't hit your mate who's holding the spindle
What you don't want to do is muck about with this. If you half- your hits and tap away at it you will just peen over your drawbar nut and make a mess of the whole thing. One BIG hit will release the taper, pretty much guaranteed.
This is the whole reason I really hate slow tapers as they either spin or lock real tight and in a milling machine invariably take quite a hit to release them. Not good for precision bearings in my opinion.
Beslaget huvudspindellager (Swedish for 'Seized main spindle bearing')
By Michael G in forum METALWORK GENERALReplies: 28Last Post: 26th Jun 2017, 06:08 PM -
Removing a Myford chuck
By BobL in forum METALWORK GENERALReplies: 21Last Post: 15th Jul 2016, 01:00 PM -
Removing a Broke Circlip /C-clip From Spindle
By thumbsucker in forum METALWORK GENERALReplies: 5Last Post: 4th Jun 2015, 07:49 PM -
Removing seized feed roller on WIA Weldmatic 150S?
By Scan_Fan in forum WELDINGReplies: 2Last Post: 18th Oct 2014, 03:38 PM -
Removing the spindle from a Sharaton 4 1/2"
By _AL_ in forum THE HERCUS AREAReplies: 4Last Post: 31st Dec 2011, 11:12 PM
