Results 1 to 15 of 16
Thread: Swivel head vice threads
23rd Oct 2018, 08:57 AM #1
Hi all,
I am making a swivel head vice as pictured.
It is to a stage where pieces of plate and pipe have been cut and partially assembled. It is awaiting a thread and nut to complete it..
It is an ongoing work in practice but slowed to a halt since my surgery. During my convalescence, I am hunting out the 10mm x 500 or so, threaded rod & nut, needed to complete the project.
I am clueless as to what threaded rod is best suited, an Acme or a square thread.
I googled some Aussie sites but they are short on info to enable selection.
Any recommendations on what to buy and the best source to buy it from?
23rd Oct 2018, 09:17 AM #2Most Valued Member
- Jul 2016
- 35
- 1,522
Square thread is going to be the strongest for a given diameter, I don't know of an easy cheap place to get it other than car scissor jacks. Acme is sourcabe from a number of places in the US or I think small bearings Australia has some but are not cheap.
23rd Oct 2018, 10:04 AM #3
Maybe you can get the thread from an Accro prop?
23rd Oct 2018, 11:05 AM #4Most Valued Member
- Healesville
- 2,129
Grahame 10mm seems a bit small to me, at the base of the thread it will be close to 8mm.
At about 500 long i reckon it will have quite a bit of torsional spring in it.
What material were you thinking of using?
cheers, shed
23rd Oct 2018, 11:32 AM #5Member: Blue and white apron brigade
I agree 8 mm is going to be pretty springy.
Ebay has 12mm SS ACME threaded rod 500mm long with a longish brass nut with collar and screw holes in it for ~$30.
https://www.ebay.com.au/itm/12mm-T12...cFhQ:rk:3:pf:1
23rd Oct 2018, 03:36 PM #6
Thanks guys,
While it is a vice. the intended purpose does not require great strength.
To explain further, the whole purpose of the vice unit is to hold awkwardly shaped items securely for light work like inletting or engraving.
Possibly a Muzzleloader rifle ( with an ancillary stand and black powder horns ( cow horns.)
I saw some heavy cell rubber at Clark Rubber about 12mm thick which I can glue in the wooden jaws.
There was no drawing, I just used the pic and guesstimated the dimensions. Stuffed up on the thread I guess?
BobL this looks like it will more than suit. The 12mm will still fit within the intended area and you cannot moan about the price.
Thanks, guys. I will post the build in project forum.
23rd Oct 2018, 04:23 PM #7
I wonder what you will get? The title says “steel screw and brass nut” the description “stainless steel screw and copper nut”.
The nut being copper rather than brass is highly unlikely but the screw could be either.…..Live a Quiet Life & Work with your Hands
23rd Oct 2018, 06:14 PM #8Diamond Member
- Aug 2006
- 1,106
Here is an Australian based option as well if you need it a bit quicker.
https://www.ebay.com.au/itm/TRPZ12X3...jS~:rk:43:pf:0
https://www.ebay.com.au/itm/CLEARANC...GiFt:rk:3:pf:0
23rd Oct 2018, 07:12 PM #9Member: Blue and white apron brigade
Rather than rubber which can mark workpieces I recommend 3mm thick rawhide or thick suede leather
I have this on my WW vices and a light turn of the handle provides fantastic grip and does not mark the work.
I also have a set of removable jaws for my regular vice and its great for holding soft metals like brass and Al.
23rd Oct 2018, 07:13 PM #10Member: Blue and white apron brigade
23rd Oct 2018, 08:15 PM #11
Hi Grahame,
You could always pinch one of the screws from a workbench !Best Regards:
23rd Oct 2018, 09:46 PM #12Philomath in training
- 6,563
ACME and square profile threads are usually used for strength over a normal thread. If the loads you apply are only going to be light, why not just grab a bit of all-thread and use that? You can always replace with an ACME later if it fails for some reason.
23rd Oct 2018, 09:52 PM #13Diamond Member
- Aug 2006
- 1,106
Won't it be a bit slower if you use all thread as it is usually a lot finer thread. I notice it a lot at work as a lot of the clamps are all thread and the better ones use acme, it is a lot quicker.
24th Oct 2018, 07:33 AM #14Senior Member
- Sep 2009
- Newcastle
- 342
In Australia you may find trapezoidal thread rather than ACME.
25th Oct 2018, 01:54 PM #15
Michael,
I used all thread in the past.
A year 11 project at high school was a 4" vice modeled along the lines of the Dawn fabricated unit. It sported an all thread screw.
It took forever to open and close. For that reason, I wanted to avoid allthread.
I ordered the 12mmm diam screw that BobL posted not yet having seen the post of cheaper one available here in Oz.
Normally a vice screw uses a captive but floating nut. I am having reservations about the Acme nut being ridgidly mounted.
I have to devise a method of making it float.
We will just have to wait and see.
I noticed the cheap acme nuts on the oz site are seconds being slightly off center.
Thanks for the input fellas.
$50 3" swivel milling vice review
By BobL in forum METALWORK GENERALReplies: 8Last Post: 2nd Jun 2018, 03:20 PM -
How to calculate the size of base required for a swivel crane?
By Alexxred in forum WELDINGReplies: 12Last Post: 15th Mar 2017, 11:09 PM -
Vice Stop ( or why the vice is still not painted Michael )
By Anorak Bob in forum METALWORK GENERALReplies: 4Last Post: 5th Jan 2016, 09:01 PM -
SOLD: Machine levelling feet with swivel 20mm stud.
By Greg Q in forum METALWORK - Machinery, Equipment, MARKETReplies: 3Last Post: 14th May 2013, 08:43 AM -
Swivel Base Revisited
By Anorak Bob in forum METALWORK GENERALReplies: 100Last Post: 8th Oct 2012, 02:33 PM
