Results 1 to 15 of 16
Thread: Rounding key ends
22nd Oct 2018, 03:34 AM #1Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,039
Rounding key ends
From time to time I mill a blind slot in a shaft and fit a key to it, usually a 1/8" to 5/16" key. My current method of rounding the ends of the key is to do it by hand on the bench grinder but I find it hard to do a neat job plus its fiddly and slow. Does anyone have a quick method or nifty homemade gizmo they use for rounding the ends of key steel?
This blurry photo almost makes my key look respectable.
22nd Oct 2018, 06:03 AM #2
Nope I did mine same as you freehand on bench grinder.
22nd Oct 2018, 06:06 AM #3
Hi Bob,
Apart from being neat and ease of fitting of whatever has to slide onto the key, there isn't any real need to round the ends.
I know its been done like that for years, and an old time craftsman would cringe and rap my knuckles if I suggested not to bother.
But you did ask and I do the same as you. Grab it with a pair of pliers and grind to shape, though an old timer would file it.Best Regards:
22nd Oct 2018, 08:48 AM #4Golden Member
- Mar 2009
- 54
- 825
I round them on a linisher and generally get good results.
The hand motions used to round something freehand and unsupported just seems to work better for me than having the key on a grinder rest.
Using a coarser belt tends to remove material quicker and cooler than a grinding wheel too.
Greg.
22nd Oct 2018, 11:22 AM #5Most Valued Member
- Australia east coast
- 2,713
22nd Oct 2018, 11:52 AM #6Member: Blue and white apron brigade
Rounding stuff works a little better on the unbacked portion of a linisher belt. On my Multitool linisher this is area is small but enough to round things like a key end. on my larger (2m x 150 mm wide) linisher theres ~100mm of unsupported belt and that is pretty handy for larger things.
22nd Oct 2018, 02:00 PM #7Most Valued Member
- Healesville
- 2,129
I also use the linisher.
I color the key ends with a texta and find a flat washer with about the same ID as the width of the key then use the ID of the
washer to scribe the radius on both sides of the key so it can be flipped when linishing.
If I am making the key from scratch I do one end while it is still attached to the stock, then after it is cut off and to hold the key for linishing the cut end I hold it with vise grips, pliers are useless for holding and grinding little things.
happy days, shed
22nd Oct 2018, 05:54 PM #8Most Valued Member
Hi Bob,
Sorry but I would just do it the same as you.
Actually, when it comes to doing the example shown in your photo, the correct method is not to use a milling cutter but a woodruff cutter. The sharp edge created with an endmill is a stress raiser and as such, critical parts should be done with a woodruff cutter. That would also negate the need to radius the end of the keyway.
Of course I don't own a single woodruff cutter and have always done what you have done. None of my parts I make are critical parts.
22nd Oct 2018, 06:20 PM #9Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 838
A woodruff cutter will also produce sharp corners, unless of course the edges of each tooth are radiused. It is pretty easy to produce a slight radius on the corner of end mill teeth using a diamond file and hand stone and even easier to do it on a 2 tooth slot drill which would be a better choice when cutting a keyway.
23rd Oct 2018, 06:58 PM #10Golden Member
- Nov 2010
- Gippsland Victoria
- 733
Could you use a small manual rotary table on the mill ? It wouldnt have to be as elaborate as this one.
https://www.youtube.com/watch?v=mVRgxBX3Lro
I guess by the time you have secured the table to the mill bed then centred and secured the workpiece you have already finshed the job with your method
30th Oct 2018, 10:35 AM #11Most Valued Member
- 4,258
leave them square..makes them easier to get out asa well.
30th Oct 2018, 03:16 PM #12Most Valued Member
- Oct 2007
- 3,112
Buy keys with rounded ends
30th Oct 2018, 06:52 PM #13Most Valued Member
- 4,890
30th Oct 2018, 08:13 PM #14Most Valued Member
- Oct 2007
- 3,112
I guess that would depend on the length you want, but I have about 50 or so keys in 3/5/6 mm of various lengths and they all have rounded ends. Indeed generally that's how they're supplied if you buy keys vs key stock (which I have in larger sizes) and rolling your own.
https://www.machineryhouse.com.au/K72310
30th Oct 2018, 10:41 PM #15
Yes you can buy them with already rounded ends !
But they come in fixed sizes and are expensive when compared to a length of key steel. The other thing is that you can rarely buy just one, usually a box of ten or twelve.
A 13" inch length of 0.250" square key steel costs 0.90p plus vat, say £1.20p, a box of 12 X 1" inch costs anything from 3.95p + vat.
It also comes in useful for other things !Best Regards:
odds and ends (junk)
By dodge at4 in forum METALWORK - Machinery, Equipment, MARKETReplies: 10Last Post: 23rd Mar 2018, 10:28 PM -
Suggestions for rounding over sharp edges on engineers square and combination squares
By barrysumpter in forum METALWORK GENERALReplies: 8Last Post: 4th Sep 2017, 09:13 AM -
mild steel brakr line ends
By leopardwood in forum METALWORK GENERALReplies: 7Last Post: 4th Apr 2011, 11:29 AM -
Flush fit for ball ends
By Tiger in forum METALWORK GENERALReplies: 12Last Post: 8th Apr 2010, 11:13 AM -
squaring the ends
By tanii51 in forum METALWORK GENERALReplies: 2Last Post: 17th Sep 2009, 09:42 AM
