Results 1 to 15 of 53
Thread: Circle calculation
25th Sep 2018, 07:36 PM #1Senior Member
- Nov 2012
- Mid North Coast NSW
- 422
Circle calculation
Trying to draw a plastic thread in autocad but i just can't get my head around the geometry to work this out.
It's to 3D print a new fuel cap for my ride on mower.
In the following exaggerated picture, the thread is like a sine wave. I know the pitch is 4mm and the thread depth is 1.2mm.
As is drawn with circles touching each other to form the wave, what diameter are the circles ?
25th Sep 2018, 08:02 PM #2Senior Member
- Jan 2012
- 149
How about 4.1761226mm?
25th Sep 2018, 08:20 PM #3Senior Member
- Nov 2012
- 422
25th Sep 2018, 08:36 PM #4Most Valued Member
Slightly larger than 2. Doesn't AutoCAD tell you the circle diameter?
25th Sep 2018, 08:43 PM #5Senior Member
- Nov 2012
- 422
25th Sep 2018, 08:52 PM #6Gear expert in training
- 34
- 1,075
Did some fiddling with trial and error and a radius of 1.134 on a 4mm pitch gives you a thread depth of 1.1985mm
Radius 1.1335 gives a depth of 1.1996
25th Sep 2018, 08:59 PM #7Most Valued Member
I did the same with Sketchup and came up with a radius of roughly 1.15, so I reckon elan is right.
25th Sep 2018, 10:35 PM #8Senior Member
- Jan 2012
- 149
Wrong first time, doubled the pitch.
I need a another go!
Whoopsie... still wrong
deleted image
25th Sep 2018, 10:39 PM #9Senior Member
- Nov 2012
- 422
Got it !
The usual light bulb moment is all it took.
The circles centers make an isosceles triangle that can be divided in half making a right angle triangle.
The right angle triangle has a base of 2 (B) and the height of 1.2 (H), so the radii of the circles is 1/2 the hypotenuse (HY).
R = Root (B squared + H squared) /2 ...answer : 1.16619.............(hard to do this stuff on a standard keyboard)
Even after entering these figures into autocad, the circles don't quite line up properly. very strange.
25th Sep 2018, 10:44 PM #10Gear expert in training
- 34
- 1,075
How are you doing that Neil?
When I plug your numbers into an AutoCAD drawing, I only get a thread depth of 1.135
25th Sep 2018, 10:51 PM #11Gear expert in training
- 34
- 1,075
25th Sep 2018, 10:51 PM #12Most Valued Member
25th Sep 2018, 10:58 PM #13Senior Member
- Jan 2012
- 149
Yes Elan, I am still wrong.
25th Sep 2018, 11:03 PM #14Gear expert in training
- 34
- 1,075
This gets you within 0.4 micron of your required depth
25th Sep 2018, 11:09 PM #15Senior Member
- Oct 2010
- NSW
- 177
2.2332381Ø
Cheers John
Another Plasma circle cutting jog
By BobL in forum WELDINGReplies: 0Last Post: 16th Nov 2016, 09:58 PM -
Diameter Of A Circle
By Keith_W in forum METALWORK GENERALReplies: 56Last Post: 27th May 2014, 03:51 PM -
Turning a square into a circle
By Vernonv in forum METALWORK GENERALReplies: 14Last Post: 29th Nov 2010, 10:47 AM -
Cutting a circle in a cylinder
By Doc58 in forum METALWORK GENERALReplies: 16Last Post: 14th Jul 2009, 12:35 PM
