Results 1 to 5 of 5
Thread: Beaver mill owner
17th Sep 2018, 01:20 PM #1Senior Member
- Mar 2011
- Taree NSW
- 119
Beaver mill owner
Hi guys,
I am looking for a Beaver VBRP MK2 mill owner who is willing to correspond with me for exchange of information , advice and any relevant information re this fabulous old mill - I have the instruction manual but can't afford at this time the 188 page workshop manual advertised for 65 GBP My current problem is a non working Y axis motor which I will attempt to remove today for my motor man to check - Have made a new coolant pump and it is working well however all switches are are in the ON position and wont turn OFF- I removed the coolant pump switch, flooded it with WD40 then blew out the excess and it now works correctly - will do the same with the other 2 switches only using contactor cleaner in lieu of WD40
all contributions gratefully received
Alf
17th Sep 2018, 07:52 PM #2
Hi Alf,
A lot of the time the old contactors get sticky plungers and don't always bottom out, leaving the contacts to arc and burn, then go open circuit.
Many of them can be taken apart and cleaned. I've actually seen dead insects under the plunger, squashed as the contactor operated.Best Regards:
31st Oct 2018, 09:54 PM #3Senior Member
- Mar 2011
- Taree NSW
- 119
Hi Baron,
All fixed -dismantled one switch which I was loath to do - spring fell out and I couldn't see where it came from - reassembled it, sprayed internals with contactor cleaner-sprayed push buttons with brake cleaner then WD40 -now all work correctly and my X axis motor works as well - all good
1st Nov 2018, 03:38 AM #4
Hi Alf,
It might pay to do a plan of the wiring, those old contactors can get quite troublesome if they have been allowed to arc and not close properly. They should operate with a firm clunk. At one time you could buy spare contacts and coils, but it seems that nowadays you have to buy the complete contactor. They never were cheap, I'll bet they are still pricey.Best Regards:
2nd Nov 2018, 08:31 AM #5Diamond Member
- N.W.Tasmania
- 1,407
Just on the subject of replaceable contacts in contactors, many years ago while I was still a young teenager, our domestic water pump was inundated when the river flooded. Dad took the motor in to the rewinders to have it dried out and checked / revarnished etc, and a neighbour who was a recently retired electrician, cleaned out the AD40 contactor, dried it in the oven, and after further electrical checks pronounced it fit for use again. He told us that they often used a thripenny bit which were pure silver, as a new contact, if the contacts were burned. A good cheap fix at the time.
Beaver Pal Mill
By KBs PensNmore in forum METALWORK - Machinery, Equipment, MARKETReplies: 3Last Post: 13th May 2018, 09:19 AM -
Beaver mill - part supplier,if any
By Alf Scotting in forum METALWORK GENERALReplies: 5Last Post: 7th Nov 2017, 08:20 AM -
Beaver lever block
By neksmerj in forum METALWORK GENERALReplies: 4Last Post: 9th Aug 2015, 09:51 PM -
Beaver lever block
By neksmerj in forum METALWORK GENERALReplies: 28Last Post: 6th Jul 2015, 08:59 PM -
Mini Mill owner who also have a Rotary Table
By Jim Ferrous in forum METALWORK GENERALReplies: 10Last Post: 21st Oct 2013, 12:30 PM
