Results 1 to 6 of 6
    Aug 2018
    CA
    47
    2
    Default 4x6 horizontal bandsaw
    What would you guys reccomend for a good metal cutting bandsaw in the $50 range?
    Aug 2018
    CA
    47
    2
    I meant $500
    just getting into metal working.
    Jul 2016
    35
    1,522
    Hi Rag, this is a bit of an Australian forum so what available here isn't quite the same as the cornucopia of used stuff avaìlable to you. For $500USD you can absolutely buy a decent new import bandsaw, probably a good swiveling one. You might even get something used thats US made like a marvel. If i were you I would start scoping out Craigslist.
    Jan 2004
    Mackay North Qld
    6,446
    Gday Rag9836
    First of all welcome to the forum.
    If you buy an import bandsaw you will find you have to some fettling to get it to run OK.
    The saws can be brought up to a good standard if you know what you are doing.
    Each of them will have a different fault to the next one.
    I don't know what $500 will buy but Grizzly as a name brand seems to pop up more that enough. They are a company that seems to sell pretty fair machine tools.
    Harbor freight is cheap but don't expect a lot of help. You know what comes with cheap.
    Some potential issues
    Wheels not concentric
    Blade tracking mechanism need s adjust
    Wheels, not co planar-means edges are all in the same plane.
    Bearings rough,
    Stock clamping vice needs to be adjusted to square to the blade alignment.
    Blade guides need to be adjusted so blade cuts perpendicular square to the deck.
    Cut with the blade tensioned high-There are u tubes on how to do this.
    Buy a new M2 bi metal grade and follow the run in guide carefully.You can ruin a good blade in moments if there is no run in procedure. Asian Factory blade is poop! Dump it after saw is tuned.
    For your new blade, select the right TPI teeth per inch to suit what you will be cutting predominantly count.Take TPI advice from blade sales people/manuafcturer
    My saw was a piece of poo when I got it but with advice from the net I have got it cutting spot on.
    Will post some pics tomorrow .
    Jan 2004
    Mackay North Qld
    6,446
    Hi Rag,
    Here ya go mate!
    Here s the Grizzly base model 6 x 4 bandsaw.
    4" x 6" Metal-Cutting Bandsaw | Grizzly Industrial
    You may well be close to a grizzly dealer and might be able to have a look in person.The Grizzly people can explain in person how to set it up.
    Any any case, get the bi metal blade and run it in according to instruction.Once the saw is set up properly and the blade run in.
    I cannot emphasise those points heavily enough. Square up the vice , adjust the blade guides square to the deck, correct saw teeth per inch to suit metal thickness to be cut and run in the new blade to instructions.
    It will cut nearly, forever without trouble.
    For example, my generic 6 x4 bandsaw is the dead spit of the one pictured (different paint though) and it has cut an average of 1 cut per day for 15 months without trouble.
    The saw takes a table to used in the blade vertical position and works well when care is used.
    God luck and tell us all, how you went.
    Tennant Creek, Aust
    61
    601
    When I was looking for a B/saw, the members here recommend me to get 200 x 125 mm (8" x 8" x 5") B/saw
    I am happy with it.
    https://www.machineryhouse.com.au/B003
    Here is one at bottom of page, that looks close to mine in grizzly catalogue.
  1. Horizontal Bandsaw 101 (BS-5S)
    By joez in forum METALWORK GENERAL
    Last Post: 5th Dec 2016, 09:55 PM
  2. Looking for a horizontal bandsaw (Melbourne)
    By joe88 in forum WANTED TO BUY
    Last Post: 31st Aug 2016, 02:03 AM
  3. SOLD: Metal bandsaw/horizontal cut-off saw
    By derekcohen in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 26th Jan 2012, 12:22 PM
  4. Horizontal bandsaw or cold cut saw
    By Nielsen in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 14th Sep 2010, 10:44 PM
  5. Horizontal/Vertical bandsaw
    By Stustoys in forum METALWORK GENERAL
    Last Post: 17th Jul 2010, 08:18 PM
