Results 1 to 3 of 3
Thread: Detail sanding tool.
28th Jul 2018, 11:42 PM #1
I wasn't sure whether to post this here or on "Tool Gloat". One of the engineering firms that I go to that allows me to rummage in their scrap bin and off cuts box, offered this to me...
No I didn't get it given, I put a fiver into the "tea box"...
It is a detail sanding stick. It came complete with a bag of ten spare abrasive tape loops. You depress the spring loaded bit on the end to change the loop. It is used for fine detail work. I'm told that the abrasive loops are diamond grit, though the one on the stick is 120 grit and the loops in the bag are 320 grit. The whole thing is about seven inches long and 6 mm wide.Best Regards:
29th Jul 2018, 12:16 AM #2Most Valued Member
That's a nifty looking tool, all you need now is to find a job for it. Nice find by the way, probably cost more than a fiver for A belt let alone 10 of them,
29th Jul 2018, 02:32 AM #3China
- Dec 2005
- South Australia
- 1,657
I have about 10 of them, very useful, belts are about $12.00 per 10
Power sanding aluminium angle - any hidden danger
By Arron in forum SAFETY FORUMReplies: 5Last Post: 5th Nov 2017, 07:50 AM -
Newbie here, sanding/polishing for aluminum?
By chughes10 in forum METALWORK GENERALReplies: 16Last Post: 21st Apr 2017, 08:02 AM -
Abranet sanding
By maxmac in forum METALWORK GENERALReplies: 2Last Post: 21st Feb 2010, 09:17 PM -
Metal sanding belts.
By Steve Fryar in forum METALWORK GENERALReplies: 5Last Post: 6th Aug 2008, 05:08 PM -
Belt Grinder /Sanding Machine Plans
By barkersegg in forum METALWORK GENERALReplies: 3Last Post: 19th Mar 2008, 08:28 AM
