Results 1 to 15 of 16
Thread: Finally, the Mill has come home.
16th Apr 2018, 12:09 AM #1Most Valued Member
Finally have a Milling machine, courtesy of John.
//metalworkforums.com/f223/t200...illing-machine
Picked it up last Saturday with a friend and his 8X5 trailer, got it home today Sunday, as he lives in Adelaide during the week, and comes home on the weekends.
Had to get an engine crane to do the heavy work, thought about hiring one, $50 for the day, I'd need to hire it several times to assemble and move the mill, plus the shaper and Hercus lathe, that are still to come. It's sitting under the carport at the moment, till I can get the shed finished. SWMBO asked "Why did I get it now?", told her "John wanted it out of the way as he's going away", "that's his problem not yours" was the reply, some women just don't understand!!!!!
Now the fun begins, working out what goes where, as it's in about 100 pieces, at least I'll know what makes it all work?
16th Apr 2018, 07:02 PM #2
Bargain
Bargain ,it looks like it has been restored already .
16th Apr 2018, 08:04 PM #3
Is your missus and my missus sister?
The seem to think alike.
Congrats on your new toy.
17th Apr 2018, 12:16 AM #4Most Valued Member
For those that can't follow the link, here are some pics of it assembled.
Would I be better off leaving it with the 3 phase motors and VFD, or swapping them over for single phase?
I don't really understand the electrics of converting single phase to 3 phase or setting the parameters, I think they're called.
If I go with the VFD, what do I stay away from, or watch out for, and what is a good brand to get, that is simple to use?
Can one unit be fitted with a socket and then swapped over for another machines use?
Sorry for all the questions, but I'm confused by it all.
Thanks,
17th Apr 2018, 12:35 AM #5Most Valued Member
17th Apr 2018, 08:56 AM #6Most Valued Member
My last two machines I bought involved a road trip to Sydney to pick them up. I'm at the stage now that if I told my wife I was going to Perth to pick up a machine, she would just roll her eyes with a smile and tell me I'm out of control!
She knows she can't really complain. I could be doing alot worse. I build and fix just about everything around the house and I logbook service both the family cars on top of working on average 50 hours a week.
I earn my keep!Girl, I don't wanna know about your mild-mannered alter ego or anything like that." I mean, you tell me you're, uh, super-mega-ultra-lightning babe? That's all right with me. I'm good. I'm good.
17th Apr 2018, 07:18 PM #7Most Valued Member
- Jul 2016
- 35
- 1,522
Is that a brown and sharpe taper in the horizontal spindle? Universal table machines can be extremely useful. Did you get much tooling?
17th Apr 2018, 07:21 PM #8Banned
- Jan 2018
- Aldinga Beach.
- 73
- 148
My wife often says it would cost us a fortune if I couldn't make or repair the things I do, most blokes just aren't that handy.
17th Apr 2018, 11:42 PM #9Most Valued Member
Fortunately this machine was only about 70kms away, but I know what you're talking about Simon, I need to get to Sydney to pick up my Surface Grinder!!!!
I think the taper is a number 3 Morse taper, according to John, we'll see when I get around to assembling it, hopefully this weekend, as SWMBO is complaining about the JUNK???? under the carport.
It would cost me a fortune also, plus our rent would go up astronomically as I do the maintenance work as required for the landlord. I have a friend that's not handy, a weekend farmer, and I'm regularly asked to fix stuff for him. Even had to do Gyprock and timber work for him.
Thanks everyone for the likes and comments.
17th Apr 2018, 11:55 PM #10Senior Member
- Oct 2015
- melbourne
- 473
Not in my opinion;you'll get variable speed with a vfd. You may still need to change belts occasionally.
You'll also need to sort out coolant pumps, lights, and maybe power feed
But you'd have to do all that anyway, if you converted to single phase.
The motor also needs to be capable of 240 Y rather than 415 Delta. (or is it the other way around?)
The other way would be a 3 phase converter, most likely some sort of rotary converter, which could be used for multiple machines.
I'm sure someone more knowledgeable will be along soon..
Russ
18th Apr 2018, 09:05 AM #11Most Valued Member
I have a couple of machines that have multiple 3 phase motors as part of their operation and in order to keep the VFV conversion economical, I run more than one motor on the VFD as once.
For instance, my surface grinder runs a spindle motor, hydraulic pump motor and coolant pump. I run all on the one VFD. The setup is simplified to an extent because I don't deviate from 50Hz and so all the motors are running at the "correct" single speed.
With a mill, you will want to capitalise on the variable speed of the VFD, so if you decide to run the spindle AND say a coolant pump from the same VFD (at the same time) then the coolant pump will change in speed too. Probably not a big deal if you keep the speed range "reasonable" but at the speed extremes the coolant pump will either not work (low speeds) or may be pushed into cavitation at high speeds.
Another example, I have in the past run my shaper from the VFD on my mill. Both motors are 3 HP and the parrameter setup on the VFD is not particularly complex so it works OK. However, the controls for the VFD are on the mill (as you would expect) and so this can be inconvenient at best and down right dangerous at worst if the controls are out of reach during operation.
18th Apr 2018, 06:48 PM #12Most Valued Member
Any chance of a pic of how you've got the VFD set up on the mill, please? Chasing up prices on VFD's now.
Thanks,
18th Apr 2018, 11:16 PM #13Golden Member
- Vic
- 48
- 544
Hi Kryn,
You need to connect the motor configuration to Delta (.ie the triangle). Open the terminal box, if you see 6 terminals then its easy to do but it there is only 3 wires coming out then you will have to open it up to disconnect the star connection and bring the other 3 ends out for the delta configuration.
I am using this on the Hercus lathe and knee milling machine and so far so good. From memory I paid around $150 each but that is a while ago. You can change the motor speed by turning the knob to adjust the output frequencies, anything under 20hz is almost unusable as there isn't enough torque to turn. I think if you get a "vector" vfd it will be usable through the range but it's expensive, I think I saw a thread with product/link under "electrical" section, not long ago about it.
https://www.ebay.com.au/itm/Hy-Serie...UAAOSwo~1awgVk
Regards,
Trong
I used the ribbon cable to extend the control panel and mount the main unit on the wall. I think this one http://www.altronics.com.au/p/w2610-10-wire-idc-cable/
here they are:
https://www.youtube.com/watch?v=vcI-L6kzW1Y
https://www.youtube.com/watch?v=F9Fo_QdPSSs
18th Apr 2018, 11:39 PM #14Golden Member
- Vic
- 48
- 544
The motor I have on the mill is star configuration, I had to bring the ends out to reconnect into delta for VFD. Just to give an idea
18th Apr 2018, 11:50 PM #15Most Valued Member
The motor has already been converted, as John the previous owner has used it on a VFD, just a matter of getting one, and wiring/setting it up.
got one finally .
By texx in forum METALWORK GENERALReplies: 13Last Post: 16th Jun 2013, 08:56 AM -
My Cooler Finally!!
By johncar in forum WELDINGReplies: 14Last Post: 9th May 2013, 07:46 AM -
Finally Finished My 260
By kwijibo99 in forum THE HERCUS AREAReplies: 8Last Post: 16th Apr 2010, 01:53 PM
