Results 1 to 15 of 17
19th Feb 2018, 07:35 PM #1
Something very different from my usual metalwork....
I've been at this project for a few weeks - quite a few, actually....
Here is the story:
A few years ago I saw a large steel sculpture I really liked - and imagined that I could build something like that one day...
Over the years a shape cristallised in my brain, but it involved a large spherical shape. Since I had no way of getting hold of anything like it, the idea slowly disappeared into the fog of other projects.
Then, as you may know, mid-2016 I started a new part-time job, inspecting large LPG tanks for standards compliance.
One of the tanks I looked at had hemispherical ends - an American brand of tanks imported in the '60s. Suddenly, I imagined the cylinder part gone and realised THERE was my sphere!
A few phone calls and negotiations later, I was given a scrapped 1500 liter LPG tank, degassed and nitrogen purged, to come and pick up. They cut a large hole in the side instead of the usual hole in an end, just to ensure it could never be used for gas again.
Once home, my plasma cutter made short work of cutting the two ends off.
Visible in the last photo is an old heavy wall (1/8") industrial fan housing which was sheltering in my scrap heap. The fan is gone and the motor now powers my lathe.
Some more plasma cutting of flat 1/8" collected plate and a lot of careful stitch welding saw the outside of the fan housing closed completely. A heavy 3x3x1/2" angle iron fully welded into one short edge allowed a suitable base frame to be attached, so the big square shape could be supported by just one corner.
Meanwhile, I cleaned up the cut edges of the two hemispheres, mounted them on my welding table and welded them together
Lots of thoughts then went into the as-slender-as-possible support of this VERY heavy sphere (3/8" wall thickness, 900mm diameter).
Eventually, my choice was a weight lifting bar designed to lift 500kg of bar bells - and not deform. It's 1-1/8" diameter and eventually around 4 ft long.
I drilled and bored a close-fitting socket hole into a block of 4"x3"x2-1/4" MS, which I welded to two cross-bars on the now wide-spread base frame, made from 1-1/2"x 1/4" wall thickness RHS. A trial assembly proved that it was a safe attachment. The bar and socket was able to carry the weight of the sphere plus my weight - alas flexing a LOT. I then decided to shorten the bar and fit a thin support inside the 800mm ex fan hole in the square shape to support the bar at about mid-span without intruding too much into the 'look'.
Next came the 'organic transformation cut' - a bit scary, because there would be no going back....
Moving the two parts onto the lawn, digging out a hole for the support frame and poiring concrete foundation blocks to safely bolt the subterranean frame to was next. All very heavy and exhausting work, I'm afraid...
Today, with the help of scared wife and my engine crane, we managed to lift the sharp-edged ball and pole into the 'black hole' and line up the pole and socket.
Refilling the hole and sewing some lawn seed followed, as well a drilling a couple of drain holes in the 'ball'.
What do think of it?
20180219_141819.jpg 20180219_182253.jpgCheers, Joe
19th Feb 2018, 07:57 PM #2Golden Member
- Oct 2001
- ACT
- 667
nice work, I like the exploded ball.
19th Feb 2018, 09:02 PM #3Senior Member
- Castlemaine
- 244
Great result Joe.
Piers
19th Feb 2018, 09:37 PM #4Most Valued Member
- Healesville
- 2,129
Great stuff joe, I reckon it looks like a crashed foo fighter
19th Feb 2018, 10:18 PM #5
Ha ha ha. I was going to call it "Black hole" (the fan housing is heavily hot-dip galvanised - and the new outside walls are not. So the whole thing needed to be painted. Black was an obvious choice to me). So the vision was something falling INTO or getting sucked into a black hole....
But now its together, it looks like some kind of seedpod sprouting OUT OF a black box... My BIL asked where the 'thing' was that hatched out of the pod ....
Any suggestions for a 'title'?Cheers, Joe
19th Feb 2018, 10:26 PM #6Senior Member
- Oct 2015
- melbourne
- 473
It sort of looks like a flower, or an egg.
I'm impressed...
"hatched"
"blooming rust"
-russ
19th Feb 2018, 11:32 PM #7
It is great visual piece, Joe,
I thought it was the model of the Death Star after Luke Skywalker had finished with it.
All jokes aside, those half hemispheres aren't light and must have taken some wrestling into alignment.
Is there a plan for using the cylindrical remainder? It is great recycling.
Will there be more garden ornaments?
There might well be an untapped market.
19th Feb 2018, 11:58 PM #8Most Valued Member
- 5,945
Hi Joe.
That is awesome, and very creative. LOVE it.
You could call it "IT WAS A GAS ATTACK" or "Someone passed wind in it"
At least no-one will steal it in a hurry, unless they come equiped with a mobile crane.
20th Feb 2018, 02:48 AM #9Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,038
"Feed Me!!" (Little Shop of Horrors)
That is very cool.
20th Feb 2018, 07:38 AM #10Most Valued Member
That is an awsome piece of work Joe!
In keeping with your original idea for a name, how about:
"Event Horizon"
20th Feb 2018, 10:11 AM #11Senior Member
- Oct 2010
- NSW
- 177
Great stuff Joe. "emergence"
20th Feb 2018, 10:20 AM #12Most Valued Member
- 4,255
yeah...great work Joe
looks like a flower bursting open to spread its pollens etc everywhere
20th Feb 2018, 10:49 AM #13Senior Member
- gold coast
- 303
Great sculpture Joe. It surpasses many of the entries Ive seen at the local festival held here every year.
20th Feb 2018, 01:00 PM #14
Thank you all! Keep the ideas for titles going. Different people see different things....
So far I like them all. "Feed Me" tickles my fancy....
The weight was the biggest issue. I couldn't lift any of the bits.... Had to use my engine crane to do anything and still wrestled with each step of the way. Lots of sweat gone into that one (and a little skin and blood).... The sphere with bar weighs about 100kg now, the box and base frame about 60kg.... it won't get moved in a hurry!
I cut the bootom of the cylindrical part of the tank off - with its legs attached - thinking it would make a great 'fire pit' (about 2.5m long). No plans for the rest of the cylinder.
I'll take a couple of photos later and see if someone has any ideas for using the remainder - about 200kg or more of rolled 3/8" steel plate.Cheers, Joe
20th Feb 2018, 10:14 PM #15Senior Member
- Oct 2015
- melbourne
- 473
Mostly Metalwork but for Leatherwork
By Old-Biker-UK in forum METALWORK GENERALReplies: 13Last Post: 23rd Aug 2015, 10:50 PM -
Its metalwork but for woodwork
By wheelinround in forum METALWORK GENERALReplies: 13Last Post: 5th Dec 2013, 03:02 PM -
My Metalwork Course
By Tez2 in forum METALWORK GENERALReplies: 9Last Post: 28th May 2009, 04:02 PM -
Metalwork Forums?
By nexusone in forum METALWORK GENERALReplies: 15Last Post: 16th Dec 2004, 11:49 PM
