Results 1 to 6 of 6
    Mar 2011
    Taree NSW
    119
    Default Beaver mill - part supplier,if any
    Hi guys,
    Have started dismantling my newly acquired beaver mill and found the coolant pump has the dreaded alloy rot
    Do any of you know if there is a parts supplier for these mills or perhaps a common pump for other applications -the pump has no makers name on it only "made in England" so it could have been supplied to other end users - will try to post photo later
    May 2011
    Murray Bridge S Aust.
    5,959
    Alf, what model Beaver is it?? Get a block of aluminium and machine one up, using the remains as a template.
    Mar 2011
    Taree NSW
    119
    Default beaver mill - part supplier, if any
    It is a VBRP Mk. 2 and I am thinking along the same lines - thanks Kryn
    Aug 2011
    4,779
    Hi there. My surface grinder is english made. I can take a pic of the coolant pump if that helps. Realistically any coolant pump would do but making a new pump casing out of al would be pretty easy. The geometry of these pump housings are pretty basic which would include an inlet and oulet port and a bored out section to clear the impeller.
    May 2011
    5,959
    Hi Alf, found an Instruction Manual on eBay, $30.00 if you're interested???
    https://www.ebay.com.au/itm/Instruct...gAAOSwk1hZ9~4r
    Mar 2011
    Taree NSW
    119
    Thanks KB
    Already purchased and had contact with other beaver owner on MW forum
    Regards, Alf
  1. Beaver lever block
    Last Post: 9th Aug 2015, 09:51 PM
  2. Beaver lever block
    Last Post: 6th Jul 2015, 08:59 PM
  3. Beaver Knee Removal
    By Jayson in forum METALWORK GENERAL
    Last Post: 28th Dec 2011, 03:59 PM
  4. Replies: 12
    Last Post: 5th Jan 2011, 12:55 AM
  5. Is a Balding Beaver any good?
    By Greg Q in forum METALWORK GENERAL
    Last Post: 27th Jun 2008, 02:03 PM
