Results 1 to 15 of 24
22nd Oct 2017, 01:44 PM #1Intermediate Member
- Apr 2016
- Australia
- 27
BF-20 Mill Questions Fitting a Collet Chuck
Anyone have this mill from H&F?
https://www.machineryhouse.com.au/m650
The spindle taper is 3MT but drawbar has an M10 thread. I'm wanting to fit a collet chuck...
So questions:
1) Can you get away with some kind of M10/M12 adapter?
2) Or best to machine a new drawbar?
Mainly because I've only seen one or two 3MT / M10 collet chucks around. I'm looking at an ER32 chuck/collets.
22nd Oct 2017, 01:50 PM #2Most Valued Member
Probably just as easy to make a new drawbar. They are pretty simple things to make.
22nd Oct 2017, 03:18 PM #3Most Valued Member
I had an ER25 collet chuck on an X2 mill, the bolt was 10 mm but only went in about 4-5 mm. It eventually stripped the thread on the bolt and damaged the thread in the collet, so I went to fix it, and found that there was an insert adapter threaded into it, which was 12 mm.
So you could get a 12 mm bolt cut off about 20+ mm of thread and drill and tap it to 10 mm, just make sure that you have ample thread to hold the drawbar.
Hope this helps.
22nd Oct 2017, 05:26 PM #4Senior Member
- Feb 2016
- NSW
- 117
Can it not be had in R8?
When I bought my first mill, as an ingenue I opted for the MT3 taper thinking it would serve some benefit in tool changing between it and a future lathe purchase. Ended up with a lathe built around MT2 tapers, while being driven up the bloody wall having to knock out MT3 taper tooling on the mill, and had no desire to swap tooling between the two anyway.
If I had my time again I would have chosen R8.
22nd Oct 2017, 05:56 PM #5Golden Member
- Nov 2010
- Gippsland Victoria
- 733
22nd Oct 2017, 06:30 PM #6Most Valued Member
Hi Bill,
My current mill has a MT4 and my new to me replacement mill has iso40. While at the time I was happy with MT4, I have grown to loathe a MT on a mill because you have to belt the crap out of the drawbar to release the tool from the taper. Not particularly good for the spindle bearings, eventhough they are not a precision bearing on these type of mills. I'm not familiar with R8 but I do believe they are a self releasing collet same as ISO (INT) 30, 40 & 50 tapers. This means that the tooling literally falls out once you loosen the drawbar. The taper is merely used to seat the tool in a precise location and not used to drive the tool. The rotational force comes from lugs that engage the tool under the taper. A much better system.
22nd Oct 2017, 06:30 PM #7Senior Member
- Jun 2013
- Tasmania
- 257
It's self releasing
22nd Oct 2017, 07:24 PM #8Golden Member
- Apr 2008
- NSW
- 537
That is not correct for NT tapers they hold after the drawbar is released and require a bang on the draw bar to release . If it just falls out after the drawbar is loosened it was never in properly and or too much oil or garbage on it . What you have been watching most likely is power drawbars that push the tooling out automatically .
22nd Oct 2017, 08:15 PM #9
Hi, My BF20 clone, MT3 taper came with an M12 self releasing drawbar. I've not had any problems with getting the taper to release properly. I do take very good care to make sure that both the socket and the mating tool holder are clean, and I do wipe both with an oiled paper towel. A plastic wine cork with a paper towel wrapped around it, makes a very good cleaning tool. Also I made a small square socket key with a fixed 100 mm long handle to tighten and loosen the drawbar, it takes very little force to eject the taper.
An ER32 collet holder also gives me about 35 mm extra headroom compared to the one originally supplied with the mill. Useful when using the RT and three jaw chuck.
HTH.Best Regards:
22nd Oct 2017, 09:17 PM #10Intermediate Member
- Apr 2016
- Australia
- 27
Thanks all.
The manual talks of an M10 thread on the drawbar but I've checked the actual thread on it today and funny thing is that it's neither and M10 or M12! Nor does it match anything imperial so I'm stuffed anyway! Not sure what on earth went wrong in the factory when this was built. It's close to an M12 but with a 12TPI thread...
I'm either going make a new draw bar up or request a replacement that has a standard thread.
To answer some other questions.
Yes can be had in R8, but I already have the mill in 3MT. And it was more accessible to buy in this version locally so I went with it. As mentioned above I don't have to knock it out anyway so 3MT doesn't bother me. There is some debate over which is better (R8 or 3MT). What I have works for me.
It's easy enough to get out by following the given instructions i.e. loosening the drawbar from the top and holding counter bearing, which forces the tool mostly out without it dropping completely out.
22nd Oct 2017, 09:35 PM #11Senior Member
- blackburn vic
- 297
At 12 TPI it is probably 1/2" Whitworth. NOT 1/2" UNC
Roger
22nd Oct 2017, 09:52 PM #12Intermediate Member
- Apr 2016
- Australia
- 27
22nd Oct 2017, 09:54 PM #13
A number of people have mentioned having a 1/2" Whitworth thread on their drawbars. I think it is a poor choice myself. My mill came with an M14 threaded drawbar which is just as bad. I have made up an M12 and an M16 drawbar. I just used some steel rod and welded a length of thread onto it. The nut end is an M10 nut welded on, but I drilled it out and turned the end of the drawbar to fit. I then fitted a thick washer under the nut before welding the end.
Most MT3 tooling will have an M12 thread. It would be easier to try and stick with the one size.
22nd Oct 2017, 10:04 PM #14Intermediate Member
- Apr 2016
- Australia
- 27
23rd Oct 2017, 12:01 AM #15
In what way do you think it is not in tolerance for a 1/2" Whit thread? Due to the rounded thread tips the size is somewhat less than 1/2". I recall a US YouTuber saying he had found this weird thread size. He measured it at 12 tpi and 31/64". He had no idea what it was.
Fitting standard M/T 3 ER32 collet chuck into a Vertex 8" Rotary Table.
By pipeclay in forum METALWORK GENERALReplies: 9Last Post: 10th Jul 2015, 06:30 AM -
Fitting collet chuck to lathe for Dummies
By Grahame Collins in forum METALWORK GENERALReplies: 18Last Post: 16th Apr 2012, 11:43 AM -
ER32 collet chuck mods-Arboga mill
By neksmerj in forum METALWORK GENERALReplies: 25Last Post: 6th May 2011, 10:53 PM -
Another idea for bad fitting splines on a mill
By Dave J in forum METALWORK GENERALReplies: 11Last Post: 6th Nov 2010, 12:47 AM -
Fitting a 250mm chuck on a face plate, 12x36 lathe
By Dave J in forum METALWORK GENERALReplies: 8Last Post: 7th Aug 2010, 12:57 PM
