Results 1 to 9 of 9
Thread: Layout fluid
20th Oct 2017, 07:57 AM #1
Layout fluid
Where are you guys buying your Dyemark or other layout fluid and can you buy it in small bottles rather than 1litre?
I hear it expires so don’t want to buy a large volume I’ll never use.…..Live a Quiet Life & Work with your Hands
20th Oct 2017, 08:02 AM #2
20th Oct 2017, 02:45 PM #3Senior Member
- Jun 2013
- Tasmania
- 257
I bought a 200ml bottle of Starrett layout dye.
I don't like it. Its really prone to flaking off and its hard to put on just a very thin layer.
I haven't used the Dykem brand but from what I've seen it seems to be better.
20th Oct 2017, 05:04 PM #4Senior Member
- Feb 2016
- NSW
- 117
I bought a small quantity (100ml) from GAMECO/Artisan Supplies. Don't tend to use it all that often so 100ml will last quite a while. About $10 from memory.
I decanted the 100ml bottle into two 50ml paint touch-up bottles with brushes in the lids. Minimizes the loss from a spill, and makes them nice and convenient to use.
I usually just use a big Sharpie for marking out most simple things.
20th Oct 2017, 06:01 PM #5Diamond Member
- N.W.Tasmania
- 1,407
There was an interesting thread some time back on this subject, with many contributions from some of the usual suspects, which may shed some more light for you. in any case it will keep you out of mischief for a while while you read it all.
Marking Fluid
21st Oct 2017, 06:58 AM #6
The thread was an interesting read...it went off more into attempts to make your own and seemed to come to an ubrupt stop in terms of the testing.
21st Oct 2017, 09:34 AM #7Philomath in training
Bit more here too - //metalworkforums.com/f65/t200320-dykem-link
21st Oct 2017, 05:05 PM #8Member
- Oct 2017
- Lismore, NSW
- 58
G'Day DSEL74,
I used blue marking medium for many years & have now found that black or grey etching primer makes a better marking medium. If it is sprayed on lightly a good fine line can be scribed into it & it is not affected by coolants, like the blue marking medium is. Best of all it's cheap & in a pressure pack. Worth a try!
Regards,
Don.
21st Oct 2017, 05:58 PM #9Senior Member
- Aug 2012
- Greenmount, W.A.
- 70
- 275
I purchased a 200ml or so bottle from Radio Spares about a year ago. Can't find the same size on their website. It had to come to W.A. by "special" courier because it is soooo dangerous, so it cost me, but there wher no alternatives here. You may do better as you are in Melbourne. They have 1 litre bottles for $86.80 + tax.
Regards,
Alan.
Layout fluid
By section1 in forum METALWORK GENERALReplies: 32Last Post: 3rd Feb 2017, 11:35 PM -
welding & cutting fluid
By meadow street in forum WELDINGReplies: 2Last Post: 31st Jan 2015, 04:49 PM -
Cutting Fluid Ratio
By Kidbee in forum METALWORK GENERALReplies: 2Last Post: 26th Aug 2013, 11:52 PM -
Layout Fluid
By m2c1Iw in forum METALWORK GENERALReplies: 25Last Post: 3rd Jan 2013, 01:49 AM -
Marking Fluid
By grunto in forum METALWORK GENERALReplies: 81Last Post: 28th Aug 2012, 12:12 AM
