Results 1 to 5 of 5
Thread: Unusual tool - what is it?
6th Oct 2017, 10:58 AM #1Senior Member
- Mar 2011
- Taree NSW
- 119
can anyone identify this tool and what it is used for - it is a No.4 morse taper arbor having a detachable nose with a No of collets which are to suit small centre drills - when you detach the nose piece via a 3 pin scroll there is a live centre - any thoughts?image001.jpg
6th Oct 2017, 12:06 PM #2Philomath in training
Looks like a live centre that (using the collets) can also hold the ends of stock too small to take a centre drill (or that you don't want to centre drill)
6th Oct 2017, 12:43 PM #3Golden Member
- Cairns, Q
- 666
Auto electricians often used to use either a rotating drill chuck or a special non-rotating chuck with bronze jaws which were only tightened enough to provide a bearing surface for the shaft in the tailstock to hold centreless starter and generator shafts while skimming their commutators. Wonder if this tool was developed to provide a more accurate version of that set up?
Frank.
7th Oct 2017, 08:08 AM #4Senior Member
- Mar 2011
- Taree NSW
- 119
7th Oct 2017, 11:42 AM #5
unusual tool
By morrisman in forum METALWORK GENERALReplies: 5Last Post: 5th Aug 2017, 06:59 PM -
Unusual hack saw
By kenny_10 in forum METALWORK GENERALReplies: 1Last Post: 20th Jun 2017, 11:04 PM -
unusual die stock
By kenny_10 in forum METALWORK GENERALReplies: 1Last Post: 6th Jan 2013, 11:55 PM -
Unusual tool post
By morrisman in forum METALWORK GENERALReplies: 2Last Post: 1st Aug 2012, 11:51 PM -
De-rusting an Unusual BBQ
By pwaite in forum METALWORK GENERALReplies: 8Last Post: 18th Feb 2007, 01:28 PM
