Results 1 to 15 of 32
1st Sep 2017, 10:23 PM #1.
- 6,459
More Tough Stuff - Filling The Holes In The Drill Press's Table
This could have been tacked onto the end of my previous thread about the Tough's table but that thread looked like it was going to unravel...
The two holes close to the table's edge had been drilled completely through the cast iron and were roughly 3/16" in diameter but they weren't round, they had been slightly skewed. I chose to bore the holes rather than simply drill them out to 5mm because I thought there would be less chipping at the entrance to the hole when bored and that the hole might indeed be round. The scope simplified alignment. I also created a step at a depth of 5mm because the cast iron plugs needed a back stop to facilitate piening. I filed several small flats around the lower portion of the plugs to provide a space for the Loctite bearing compound I used as a backup. The shallow hole near the table centre required the drilling of a small vent hole, 1.6mm dia. though the thickness of the casting and the hole itself opened up to 6mm to include its margins.
Masking tape prevented marring while filing initially with a lathe file, followed by a rectangular section riffler along with an assortment of needle files bowed to cut only on a portion of their teeth. A scrap of 120 grade wet and dry wrapped around a small block of cast iron finished things off.
BT
1st Sep 2017, 10:28 PM #2
Wow
Sent from my iPhone using Tapatalk…..Live a Quiet Life & Work with your Hands
1st Sep 2017, 10:49 PM #3Most Valued Member
Can't believe it's the same table.
1st Sep 2017, 11:05 PM #4Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
Right. Now let's see you fix the nick on the table's rim.
Jordan
2nd Sep 2017, 09:48 AM #5Most Valued Member
- Sep 2011
- Ballarat
- 3,103
You constantly amaze me Bob
Phil
2nd Sep 2017, 09:50 AM #6
2nd Sep 2017, 10:27 AM #7Philomath in training
Isoma and the small Kaiser boring head? A precision fix then!
2nd Sep 2017, 10:32 AM #8Senior Member
- Castlemaine
- 244
Nice work BT.
Are you going to clean up the cast edge of the slots?
Piers
P.S if you ever need some money for the pokies, I will take that boring head off your hands....
2nd Sep 2017, 11:21 AM #9.
- 6,459
Thanks for all the likes you blokes. I posted this to show that sometimes with a bit of patience you can deal with the handiwork of the careless. I was fortunate that with this table the abuse was minimal. I was also extremely fortunate to have access to Alan's lathe.
The edge nick does need to be dealt with. I had been thinking of simply filling it with Devcon Steel Putty but the more I thought about it the more it seemed like a pussyish solution. I'm hatching a plugging plan.
And Piers, probably no more than touch up with a file.
BT
PS Piers. You'd probably lose the bitty Kaiser in one of the Maho's tee slots! Better it stays here.
2nd Sep 2017, 12:11 PM #10future machinist
- Mar 2008
- nowra
- 1,598
Beautiful Fix Bob I wouldn't expect anything less. Maybe you could fix the nick on the edge with devcon mixed with cast iron dust ?
The only thing your Missing now Is a Schaublin lathe too go with those nice swiss tools.BETTER TO HAVE TOOLS YOU DON'T NEED THAN TO NEED TOOLS YOU DON'T HAVE
Andre
2nd Sep 2017, 12:41 PM #11.
- 6,459
Thank you Andre.
I still may have to resort to Devcon if my plugging plan fails and a combination of dust and putty might be a better colour match.
I used to think that owning a delicious tooled 102 or even a little 70 would be the ant's pants but having spent years looking at Schaublin prices on eBay I've realised that it would be just a dream. Dreaming is good though and they do come true at times, the 13 and its accessories being proof.
In reality, my 1969 9" Hercus does most of what I need and more importantly I enjoy using it. I'm happy with what I have.
Bob.
2nd Sep 2017, 08:42 PM #12.
- 6,459
2nd Sep 2017, 08:52 PM #13
Unbelievable Bob! Love your work.
Sent from my InFocus M808 using TapatalkCheers, Joe
2nd Sep 2017, 08:55 PM #14
Hi Bob,
Very nice work there
Jordan, Stick that in your pipe...Best Regards:
2nd Sep 2017, 09:11 PM #15Most Valued Member
What the above said. Is there no end to your skills?
Tough Drill Press RPM Table?
By Burnsy in forum METALWORK GENERALReplies: 3Last Post: 13th Aug 2014, 08:29 PM -
Tough drill press
By node105 in forum METALWORK GENERALReplies: 17Last Post: 5th Jun 2013, 05:06 AM -
SOLD: TOUGH made in Australia drill press
By kieran99 in forum METALWORK - Machinery, Equipment, MARKETReplies: 11Last Post: 17th Dec 2012, 09:14 AM -
More Drill Stuff - A Tough To Progress Graft
By Anorak Bob in forum METALWORK GENERALReplies: 11Last Post: 19th Mar 2012, 10:53 AM -
Tough Drill Press (gloat)
By Bryan in forum METALWORK GENERALReplies: 49Last Post: 1st Sep 2011, 12:06 AM
