Results 1 to 4 of 4
11th Jun 2017, 01:17 PM #1Member
- Aug 2016
- 80
Waldown drill - How to remove spindle from quill?
I'd like to replace the bearings on a 2M Waldown drill press spindle, so I've removed the quill (with spindle) and the large circlip and shim at the bottom. I'm not sure exactly how to remove the spindle though.
There is a small circlip on the spindle way down inside the quill above the bearings but I don't see how that can be removed. I've looked at the exploded diagram from brobo and seems to me that I should be able to push/press/hammer the spindle out the bottom once the big circlip is removed, can anyone confirm this or tell me how to do it?
17th Jun 2017, 06:52 PM #2Senior Member
- Apr 2014
- 134
hi
if you put this into metalwork general you might get a better response
steve
18th Jun 2017, 03:09 AM #3
It just pushes out. Please don't use a hammer - the spindle is not hardened! If you have access to a press with that capacity (in terms of length) it will come out easy. Not much force required. Even something improvised would work.
Cheers, Joe
18th Jun 2017, 06:47 AM #4
Hafco HM46 Spindle / Quill Wobble
By A J in WA in forum METALWORK GENERALReplies: 3Last Post: 12th Apr 2017, 01:08 AM -
How to remove these unusual spindle nuts?
By Gunnaduit in forum METALWORK GENERALReplies: 14Last Post: 22nd Oct 2016, 08:13 PM -
How do you remove the #2Morse Taper Shank From A Jacobs Drill Chuck ?
By RoyG in forum METALWORK GENERALReplies: 13Last Post: 15th Apr 2016, 10:40 PM -
Waldown type H drill press info reqd. (spindle lubrication)
By johntopp in forum METALWORK GENERALReplies: 2Last Post: 18th Nov 2014, 03:56 PM -
Drill press quill feed return spring fitment
By Com_VC in forum METALWORK GENERALReplies: 4Last Post: 2nd Jan 2014, 08:02 PM
