Results 1 to 13 of 13
Thread: Will This Work?
10th Jun 2017, 11:15 AM #1
Will This Work?
I picked up a couple of fans from a decommissioned piece of equipment at work, when I got home I saw they were 24v not 12v.
Couple of weeks later I rescued this.
The plan for the fans are to cut a hole in the back of both my mill and lathe where the circuit boards are and use the fans to cool the circuit boards.
My shed get to 60°C plus in summer.
10th Jun 2017, 11:31 AM #2Senior Member
- Oct 2015
- melbourne
- 473
The fans may work well enough on 12v, if you have that available? (Maybe put a filter on the air intake as well) . Otherwise, check the voltage on the charger, its a bit hard to read but if it is for 24v lead acid, the terminal voltage especially under the very low load of the fan could be a bit high. Not really likely to result in smoke I think, but could be noisy with a short life...
-russ
10th Jun 2017, 11:38 AM #3Member
- Jun 2010
- Wimmera
- 96
I have several 24v fans running on 12v for different purposes.
Run a bit slower but very quiet. Run on 24v and they are noisy.
Hooroo
John
10th Jun 2017, 11:47 AM #4Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,894
Worth trying this cheap board?
Ebay item 311592258575
Jordan
10th Jun 2017, 02:18 PM #5Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
Just the other day I salvaged a 24v power supply from a discarded printer, maybe keep an eye out for old printers
10th Jun 2017, 03:55 PM #6Member: Blue and white apron brigade
- 7,182
The battery charger is perhaps a bit of over kill.
The fans are less than 1/2 A so something like a old laptop or printer power adapter 16-24V would cope quite easily and be better for the fans in the long run than running them on 12V.
I have a 24V fans that I have run from an 18V wall wart (from an old power tool recharger) for many weeks without any problems. When I finally checked the V out of the Walmart its was something like 23V.
BTW always check the voltage coming out of those adapters - some of them have as much as double the rated V. Only one has ever had less than the rated V.
11th Jun 2017, 01:08 AM #7
A lot of reticulation timers use 24volt wall warts.(Linear transformers)
Cheap and plentiful.I've become a tool of my tools.
12th Jun 2017, 12:10 AM #8Member
- Sep 2015
- 62
Aren't they 24VAC?
12th Jun 2017, 12:14 AM #9
12th Jun 2017, 12:15 AM #10Member
- Sep 2015
- 62
No. I meant the retic systems.
12th Jun 2017, 10:30 AM #11Member: Blue and white apron brigade
- 7,182
12th Jun 2017, 10:30 PM #12
12th Jun 2017, 10:44 PM #13Member
- Sep 2015
- 62
No worries, I did a bit of research and it appears some of the fans are ac/dc compatible. Depending on if they are permanent magnet versions. Anyway, 12V dc is what most computer modders run their 24v fans at to keep the noise down.
VFD's. How they work
By neksmerj in forum METALWORK GENERALReplies: 0Last Post: 9th Jun 2015, 06:02 PM -
Work Magazine
By CGroves in forum METALWORK GENERALReplies: 2Last Post: 22nd Sep 2012, 10:20 AM -
RFQ: Lathe Work And Mill Work
By twistedfuse in forum METALWORK GENERALReplies: 4Last Post: 18th Jan 2012, 04:23 PM -
How often does something not work'
By pipeclay in forum METALWORK GENERALReplies: 19Last Post: 30th Nov 2011, 07:19 AM -
It does work
By xr6t in forum METALWORK GENERALReplies: 7Last Post: 9th Jan 2010, 03:07 PM
