Results 1 to 15 of 19
Thread: copper tube
6th Jun 2017, 05:54 PM #1
copper tube
Hi,
anyone know of a supplier of 6 inch diameter copper tube?
I need a length of 660 mm long 150 mm id 2.5 mm wall thickness
for making a copper boiler for a 5" gauge locomotive I'm about to start on,
I,m located near the Gold Coast
Leroy.
6th Jun 2017, 06:08 PM #2Philomath in training
From memory, I think the model engineering guys roll some flat and then do a butt joint, reinforced with a strip. The easiest thing may be to talk to a local model engineering club as they could probably tell you what is normally done as well as advise about necessary boiler inspections/ certifications. I sat in on a club meeting about a year ago and boiler certification/ inspection is one thing they take really seriously as their insurance relies on it.
6th Jun 2017, 06:30 PM #3
Hi, yes I know about rolling flat plate into tube and may finish up doing that in the end,
I,m building this with the help of members of QSMEE of which I,m a member,
I,m just starting to collect all the materials for the boiler and sometimes if your lucky
someone will have an offcut that is just what you need, can,t hurt to ask,
Leroy
6th Jun 2017, 07:24 PM #4Golden Member
- Vic
- 48
- 544
we have this guy in Victoria George White | Australia's leading stockist & distributor of non-ferrous metals
6th Jun 2017, 08:40 PM #5Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,039
Plumbers, plumbers suppliers, refrigeration suppliers. Some types of copper pipe are more suitable for boilers than others.
7th Jun 2017, 12:34 AM #6Diamond Member
- N.W.Tasmania
- 1,407
Sounds like a great project Leroy, hope you keep us informed with lots of pictures as the work unfolds. You would be familiar with Australian Model Engineering, the magazine, and its advertisers I presume, the only other possible source That I can think of is a plumbing business doing multi storey office or residential blocks, or perhaps firms like Chubb or Wormalds who do fire suppression systems for large buildings. I have worked in the past on a couple of such projects, and know of 100 mm copper mains, not sure if they had larger closer to the incoming main at the meter area. Also not sure of the wall thickness either of that large copper tube. A letter to the "Letter Box" section of the magazine mentioned above might flush out some material. Good luck, and don't forget the pics,
Rob
7th Jun 2017, 09:17 AM #7Most Valued Member
- 4,258
mechanical services plumbers/pipe fitters where they may have some on the shelf and would be willing to cut a bit off.
6" is to big for refrigeration.
I'm guessing you would have to buy a full length from a supplier like Reece or Tradelink.
7th Jun 2017, 08:11 PM #8New Member
- Apr 2016
- 6
Your best bet for a copper tube will be the local fire hydrant installers for buildings. I got some 40mm(small by their sizes) for a bar foot rail.
Next place I would look is the metal scrap merchants, great source of short bits of copper, brass etc.
Cheers Ian
7th Jun 2017, 08:32 PM #9
7th Jun 2017, 09:05 PM #10
What about the QSMEE members.
Surely one of them has built a loco before and at least they should know where to obtain the correct size tube.
7th Jun 2017, 10:19 PM #11
8th Jun 2017, 06:09 PM #12Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
8th Jun 2017, 07:04 PM #13New Member
- Apr 2016
- 6
8th Jun 2017, 07:27 PM #14Most Valued Member
- Oct 2010
- 1,910
8th Jun 2017, 07:36 PM #15Philomath in training
In SA we go to Surman metals - Suman Metals: Copper
The copper page (linked) only goes up to 4" tube. It may be that 6" is special order territory and in that case you will probably be paying for a full length if it exists.
On edit - digging around some more there is copper tube available as 152.4x2.64 or 152.4x2.03 which is copper tube to AS1432 type A and B respectively. This from a publication by Kembla copper/ Crane copper. You may need to phone them and find out who they supply to and see if you can get an offcut. http://www.cranecopper.com.au/downlo..._Tube_2010.pdfLast edited by Michael G; 8th Jun 2017 at 07:48 PM. Reason: But wait - there's more...
Rolling copper
By denncarm in forum METALWORK GENERALReplies: 5Last Post: 27th Oct 2013, 05:15 PM -
Soldering Copper
By chillout in forum METALWORK GENERALReplies: 14Last Post: 13th Nov 2008, 05:53 PM -
Copper to copper
By slepax in forum WELDINGReplies: 4Last Post: 19th Oct 2008, 04:10 PM -
Machining copper?
By neksmerj in forum METALWORK GENERALReplies: 5Last Post: 5th Nov 2007, 10:31 AM -
Welding Copper Tube
By Edd in forum WELDINGReplies: 24Last Post: 11th Oct 2006, 03:45 PM
