Results 1 to 9 of 9
    Jun 2004
    Kyabram. Vic
    632
    Default It started out as a 'simple' job.
    Like the title says; it was just going to be a simple job to remove the vertical head and set up a horizontal milling arbor to mill 3 slits in a new chuck backplate.
    Removing the 150kg or so vertical head is relatively easy. Done.
    Next thing then is to clean up an unused by me (but some rough use by others previously) 1" X 40 taper arbor, spacer sleeves and running sleeve . Years of crud and surface rust cleaned up ok, but it has been a shop made taper and is not quite perfect.
    Next thing is that the running sleeve doesn't fit the support bush. It is a standard 1 7/8" bush. It appears that it has been turned down to 1 15/16" most likely from a standard 2" version. Why the odd size; who knows.
    Next idea is to fit a good 1" X 4mt mandrel to the lathe and turn the running sleeve down. It is hardened, but a file cuts it ok. Mandrel by itself runs straight. Stack the bush and spacer sleeves and there is runout on the outer end of the sleeve; but chuck end is ok. These spacers have been turned and bored on the lathe. Shorter ones had been dry ground on the ends on the T & CG. These sleeves were from .0005" to .003" out of square on the ends. The running sleeve was much worse as well as damaged on the ends. Somewhere around .008" to .010" over both ends to true up. As a result the stack is pushed off square on the mandrel and most likely is the cause of the runout.
    Fire up the surface grinder which hasn't been used for a while. Low coolant; so have to lug 45ltrs of fresh rainwater from the house tanks (80 metres away) to top up
    the coolant tank.
    The commercial sleeves on the arbor are a mess; out of square, damaged by swarf and dinged. So far one has had .008" ground off one end as one side appeared to have been crushed. So much for precision surfaces.
    Back to the grind tomorrow.
    Ken (who has almost forgotten what the original job was)
    May 2011
    Murray Bridge S Aust.
    5,958
    I've never heard of a simple job, always take me about 3 hours. Now, where did I put that special tool too??????
    Mar 2017
    gold coast
    47
    there's a hole in the bucket dear lisa dear lisa.
    I think we've all been there. usually love jobs for mate of a mate adding another gear for a Fiat 600. ask me how I know.
    Jun 2008
    Victoria, Australia
    74
    5,080
    Hi Ken,
    Sounds like a normal day around here. What mill are you putting the horizontal head on? Don't you already have a Adcock & Shipley, Or are you doing something with the Rossi?
    Jun 2004
    Kyabram. Vic
    632
    ppdmiami.
    I found a bucket without a hole for the water transfer.
    Ray,
    The A&S has had a crash sometime in it's previous life and a plastic cover on the end of the table was badly cracked. Looked like the cracks had been patched with epoxy; but the oil splash from inside caused the epoxy to fail. I cleaned it up and tried the Loctite cyno glue and it worked great for a couple of years, but it also failed in last summers heat. I have stripped off the broken cover and have done a bit of head scratching with it. I was considering milling a new cover from ally billet but with all the different angles; the set ups were going to be a royal pain in the asre. Looking at a jig and Tiging up from plate. Anyway the 8" rotary is too big for the table.
    I just lifted the vertical head off the Rossi and set up for horizontal. That's when the rot set in.
    Anyway; I finished end grinding the rest of the spacers today. Some equal to my turned ones and others worse. They are all a damn site better now. Even did the nuts; arbor ones that is. Many of the spacers have been hardened and noticably harder than the 1045 I used.
    Trial fitted the running spacer and spacers on the lathe arbor and they appeared to go together much nicer. The DTI tomorrow will tell me if I am kidding myself or not.
    Ken
    Jun 2008
    Victoria, Australia
    74
    5,080
    Quote Originally Posted by Toggy View Post
    ppdmiami.
    Ray,
    Ken
    How big is the A&S plastic cover? I just got a heap of 3/4" thick black polythene offcuts. You are welcome to grab some bits next time you are coming past.
    Black poly welds nicely.
    Jun 2004
    Kyabram. Vic
    632
    Thanks for the offer Ray. The base and rear end are the mounting points and are about 10mm. The inward angled sides, flat top and front are 4-5mm and a tight fit against the leadscrew.
    Ken
    Jun 2004
    Kyabram. Vic
    632
    Well that was an anti-climax. 3 x 30mm deep slits in short time in the 10mm thick wall of the 'shank' of a lathe chuck backplate. Hard cast iron. Slitting saw was a second hand used Sutton 6" X 1/16" X 3 TPI with the key slot ripped out in a previous unknown accident. I pass with the full 30mm depth of cut. Arbor a slow 38 RPM and slow hand feed. Blade lube was (rightly or wrongly) spray bottle CRC to prevent binding in the cut.
    The reworked running sleeve and precision ground sleeve ends worked a treat. No noticable runout in arbor or slitting saw. No saw slippage with only tight friction drive.
    Ken
    Sep 2011
    Emerald Central Qld
    349
    We all seem to have had the same " it will only take a few Minutes , days later.
  1. UniMi 240 - help please to get started
    By MKeech in forum METALWORK GENERAL
    Last Post: 18th Sep 2014, 11:41 PM
  2. And the day started so well...
    By bwal74 in forum METALWORK GENERAL
    Last Post: 31st Dec 2013, 06:38 PM
  3. New thread started in CNC area
    Last Post: 4th May 2012, 12:18 AM
  4. Using a Mill - Where to get started?
    By John H in forum METALWORK GENERAL
    Last Post: 8th Sep 2006, 06:59 PM
