Results 16 to 22 of 22
Thread: Fuji Frenic mini VFD!
11th May 2017, 05:09 PM #16Most Valued Member
- Healesville
- 2,129
Warrick & Eskimo, just to clear up what i said in my post above, I was not referring to the VFD voltage requirements.
I was referring to the statement that Warrick made in his post
"it is rated for 240v 3phase not 415v as we have in Aust".
11th May 2017, 05:10 PM #17
If you have a quick look at the manual you can see that they make two different models for 3 phase and single phase
The connections can be seen in the photo below
Rick
11th May 2017, 05:13 PM #18Most Valued Member
- 4,258
11th May 2017, 05:20 PM #19
11th May 2017, 07:00 PM #20
Re-read what Ray wrote: "just connect it to single phase" (even without a motor connected) and see if it powers up without error message. If it tells you a phase is missing, then bridge the vacant connector to one of the connected ones. If it still reports a missing phase, I suspect you are out of luck.
Cheers, Joe
11th May 2017, 07:39 PM #21
A magnetic contactor (MC) should, if necessary, be mounted independent of the MCCB or ELCB to cut off the
power fed to the inverter. Refer to Chapter 6, Section 6.3. [ 1 ] for details. MCs or solenoids that are to be installed
close to the inverter require connecting surge absorbers in parallel to their coils.
13th May 2017, 09:21 AM #22
I don't have three-phase, but I know the lathe was hard wired to three-phase in it previous home.
I had another look last night but couldn't see any tags on the motor.
Mini Lathe
By Mutawintji in forum METALWORK GENERALReplies: 32Last Post: 25th Apr 2013, 01:35 PM -
SOLD: The Mini Lathe
By Big Shed in forum METALWORK - Machinery, Equipment, MARKETReplies: 1Last Post: 30th Jan 2011, 10:23 AM -
Mini Lathe
By elderly in forum METALWORK GENERALReplies: 12Last Post: 1st Dec 2010, 09:21 PM -
Mini Lathe
By dj_pnevans in forum METALWORK GENERALReplies: 1Last Post: 22nd Apr 2010, 11:46 PM -
Mini Lathe
By Bodgy in forum METALWORK GENERALReplies: 6Last Post: 6th Aug 2005, 11:50 PM
