Results 1 to 13 of 13
    Jun 2005
    Helensburgh
    618
    Default Carbide Spade Drill Bits
    I am looking to buy a 3/16 or therabouts Carbide spade drill bit, what is the best source? I have done the Goggle search and besides McJings I can't find anyone one else in Oz besides Blackwoods.
    CHRIS
    7,189
    What are you intending to drill?
    Jun 2005
    Helensburgh
    618
    Saw Plate
    CHRIS
    7,189
    Quote Originally Posted by Chris Parks View Post
    Saw Plate
    It can be drilled with a concrete carbide tipped bit in a drill press using slow speed, lots of coolant/lube and high pressure.
    I prefer to drill from both sides (Drill from once side till it breaks through the the other side and back and forth) as it seems to help the carbide stay together.
    Either way expect to destroy a bit or even in the process but they are cheap enough unless you need to drill lots of holes.
    Jun 2005
    Helensburgh
    618
    I can buy a carbide bit for $20 and it won't be destroyed so I don't see the point of using a masonry drill bit. I was hoping to find one smaller than the 5mm which is the smallest McJings stock.
    CHRIS
    7,189
    Depends how may holes you want to drill.
    If you just want a few holes, small concrete bits are a lot cheaper than $20.
    A set of 15 bits (3 to 10mm) at bunnings costs less than $8
    But I see bunnings only has metric concrete bits and I assume you want a 3/16" hole?
    Same with their tile drills which are spade like carbide bits
    What about a 4mm carbide and a needle file?
    Have you tried a cobalt bit - it depends on how hard the saw plate is but I have drilled some saw plate with a cobalt bit.
    Once again slower than usual seed, high pressure and lots of lube coolant.
    Jun 2008
    Victoria, Australia
    74
    5,080
    Hi Chris,
    I have been buying the 3/16 carbide spade bits from Isaac at Blackburn tools, they cut through saw plate like butter.
    Blackburn Tools - Solid carbide spade drill bits
    If you have good diamond grinding facilities, I daresay you could rework a masonry bit in the manner Bob is suggesting.
    Also
    3/16" Solid Carbide Spade Drill
    More expensive
    Straight Flute/Spade Drills | Travers.com
    Not much in Australia unfortunately.
    Oct 2010
    melbourne, laverton
    1,910
    hi chris how are you??whats wrong with with just a normal carbide drill?
    azz
    Jun 2008
    Victoria, Australia
    74
    5,080
    Quote Originally Posted by azzrock View Post
    azz
    With a normal carbide twist drill, the edges chip too easily.
    Oct 2010
    melbourne, laverton
    1,910
    Nice ray . The edges of the drill?
    What about straight flute ones
    Jun 2008
    Victoria, Australia
    74
    5,080
    Never tried straight flute, it was easier to just use carbide spade bits.
    Oct 2010
    melbourne, laverton
    1,910
    Default straight flute
    ive used one a bit about 5mm to drill holes in what i think are hss hack saw blades
    it worked great
    azz
    Jun 2005
    Helensburgh
    618
    Thanks for all the suggestions, I was really trying to buy in Oz but it looks like Blackburn Tools are the easiest source to use. I used to have access to a CNC punch press but sadly no longer, such is life.
    CHRIS
  1. Drill bits and holesaws
    By dmaher in forum METALWORK GENERAL
    Last Post: 14th Nov 2017, 01:27 AM
  2. Sharpening brazed carbide bits
    Last Post: 17th Aug 2015, 11:22 PM
  3. Chinese carbide small milling bits
    By rusel in forum METALWORK GENERAL
    Last Post: 14th Sep 2011, 07:19 PM
  4. How Do I Sharpen Solid Carbide Drill Bits?
    By mike48 in forum METALWORK GENERAL
    Last Post: 13th Oct 2009, 12:21 AM
  5. Drill bits
    By Tiger in forum METALWORK GENERAL
    Last Post: 19th Oct 2008, 11:43 PM
