Results 1 to 6 of 6
Thread: Tapering Steel Tube
24th Mar 2017, 10:54 AM #1Novice
- Jul 2012
- Marrickville NSW
- 21
Tapering Steel Tube
G'day
Looking for some one who can put a taper on steel tubing . A friend of mine who is not computer literate has been building Peny Farthings for years and the firm he used to have it done by is no longer around. It would not be a large order and from memory the tube size would be 1 1/2'" to 1" over about 6".
Thanks Hugh
24th Mar 2017, 04:20 PM #2Most Valued Member
Hi Hugh,
I doubt anyone on here would have the tooling to do this sort of thing, it would be someone who specializes in working with tube as the cost of the tooling to do such a thing would possibly run into several thousand dollars. Best bet would be to contact several exhaust places and see what they can come up with.
H and F have tapered former's that are used with a slapper if he wants to do it himself. Hopefully the link below will work.
T Dollies, Sand Bags, Mallets & Hammers | For Sale Sydney Brisbane Melbourne Perth | Buy Workshop Equipment & Machinery online at machineryhouse.com.au
24th Mar 2017, 04:43 PM #3Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,039
Sounds like a job for someone who is good at custom exhausts. Cut a tapered slice out of the length of 1 1/2" pipe, close the gap, weld. That is typically how the header pipe for a set of lakes headers is made. Much easier to say than do.
Other than that, some sort of hydraulic former.
26th Mar 2017, 06:58 AM #4Novice
- Jul 2012
- Marrickville NSW
- 21
G'day
Thanks for the replies and ideas. I will pass the info on and see which way he wants to go.
Hugh
26th Mar 2017, 09:34 AM #5Senior Member
- Dec 2010
- Syd
- 492
Most of the bike tubing would be hydroformed for that application, I can think of someone down Picton way who has quite a bit of experience doing that stuff - at least in larger diameters, but he still might be in gaol.
26th Mar 2017, 12:07 PM #6Member
- Mar 2012
- adelaide
- 91
There is a place here in Adelaide that has a machine for doing this , there bead and butter work used to be for the steel tubed furniture industry( think tapered kitchen table legs), may be worth a look down that avenue ( steel furniture manufacturers) in NSW
Swaging 1.5" stainless steel tube
By bob ward in forum METALWORK GENERALReplies: 4Last Post: 30th May 2014, 02:54 PM -
VICTORIA 150 x 50 x 3 x 8m steel rectangular tube
By GZBMW in forum METALWORK - Machinery, Equipment, MARKETReplies: 1Last Post: 27th Feb 2012, 11:25 PM -
Nesting steel square tube
By Lyle in forum METALWORK GENERALReplies: 14Last Post: 27th May 2011, 04:14 PM -
A little bit of galvanised steel tube
By springwater in forum METALWORK GENERALReplies: 11Last Post: 15th Mar 2011, 08:36 PM -
DOM steel tube in Perth
By hitachi230 in forum METALWORK GENERALReplies: 4Last Post: 23rd Feb 2008, 09:22 AM
