Results 1 to 1 of 1
Thread: Handle of the cva quill.
22nd Mar 2017, 05:02 PM #1future machinist
- Mar 2008
- nowra
- 1,598
When I got my mill it was missing the handle for the quill. I really needed to drill some holes so I fabricated one from aluminium. I did see what the original handle looked like as it was on the CVA that morrisman purchased, I didn't really feel like making a period correct handle
I started with a 65mm diameter piece and used the rotary table to machine a boss, then over to the shaper to cut the clamping slot.
The handle itself is a pice of flat bar, I put it in the 4 jaw and machined the corners off and put an ergonomic taper on it. After welding the two pieces together I reamed the hole and now I have one functional drill handle.BETTER TO HAVE TOOLS YOU DON'T NEED THAN TO NEED TOOLS YOU DON'T HAVE
Andre
Quill bearings replacement
By jackaroo in forum METALWORK GENERALReplies: 9Last Post: 6th Aug 2016, 10:55 PM -
What's the name of the handle that holds a tap?
By 19brendan81 in forum METALWORK GENERALReplies: 3Last Post: 27th Nov 2014, 01:42 PM -
Custom Quill
By DaveTTC in forum METALWORK GENERALReplies: 16Last Post: 11th Apr 2014, 06:47 PM -
HM 52 quill slot
By Dave J in forum METALWORK GENERALReplies: 15Last Post: 6th Jan 2013, 04:28 PM -
DRO for the quill
By simonl in forum METALWORK GENERALReplies: 10Last Post: 2nd Feb 2012, 06:03 PM
