Results 1 to 8 of 8
Thread: Finally milling
25th Feb 2017, 07:35 AM #1Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
Finally milling
[some of you may remember I have this little
Mill sitting around.
I finally got it running.
So I can do a repair job on my Colchester lathe apron. After all these years I've finally done some cutting. I'm just running it with original motor(slow winding and a hysang vfd.
So far so good
.IMG]https://uploads.tapatalk-cdn.com/20170224/d8c89baf4e498db96fa74f0ae2e619c1.jpg[/IMG]
25th Feb 2017, 08:06 AM #2Most Valued Member
- Oct 2010
- 1,910
17th Apr 2017, 02:09 AM #3Most Valued Member
- Oct 2010
- 1,910
New donk.
The old things got a new donk. It's down the bottom to the right. One day I'll clean up.
I've just been getting to know the machine while I wait for a edge/centre finder In the post.
17th Apr 2017, 09:59 AM #4Most Valued Member
- Australia east coast
- 2,713
What did you do with the old 2 speed motor? It looks about the right size to refit to my Romanian mill if you want to part with it. The previous owner of mine fitted a 240V single speed 3 phase motor and tossed the 415V one in the trash, the idiot. I want the machine back to how it's supposed to be so I don't have to second-guess speeds and feed rates (he also didn't fit a frequency display or tach).
PDW
17th Apr 2017, 11:12 PM #5Most Valued Member
- Oct 2010
- 1,910
18th Apr 2017, 07:29 AM #6
[QUOTE=azzrock;1918613][some of you may remember I have this little
So far so good]
When you say slow winding and Hysang VFD,was the motor still wired in Star configuration.Shane
Got the square peg in the round hole, now can't get it out !!
18th Apr 2017, 08:35 AM #7Most Valued Member
- Oct 2010
- 1,910
18th Apr 2017, 10:01 AM #8Most Valued Member
- 2,713
No rush, just keep me in mind if you don't need it any more.
Finally got back to the Tos grinder the other day. It too has a 2 speed motor, as I thought. Even better, it works.
Pity I found a small casting with a crack in it that failed as I replaced the table. TIG brazing is now on the job list.
PDW
got one finally .
By texx in forum METALWORK GENERALReplies: 13Last Post: 16th Jun 2013, 08:56 AM -
My Cooler Finally!!
By johncar in forum WELDINGReplies: 14Last Post: 9th May 2013, 07:46 AM -
Finally Finished My 260
By kwijibo99 in forum THE HERCUS AREAReplies: 8Last Post: 16th Apr 2010, 01:53 PM
