Results 1 to 13 of 13
Thread: Dykem link
23rd Feb 2017, 10:10 PM #1
Dykem link
Guys I've located Dykem http://www.waltersandwalters.co.uk/D...id-80600-80400 it's a UK website, AU$13 and shipping is about AU$25 for 236ml bottle. I've had a look around Australia for it and had no luck, hobbies and engineering supplies sells something similar but it's only a 100ml bottle that costs $10 and shipping is $25. Do the math 20,000km away the shipping is the same as 69km away plus you get 136ml more for an extra $3 and a brand that is trusted as opposed to a brand that they don't even know what it is.
What's happening to our country.
23rd Feb 2017, 11:42 PM #2Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
I'm sure I've seen Dykem on a shelf somewhere recently, it might have been these guys in S.A General Tools Home Page
might be worth calling and asking
24th Feb 2017, 03:52 AM #3
I don't know about You folks access to various chemicals but if Copper sulfate is available You can make flash copper plating to use for marking out. I use it on tool bits when grinding. It uses battery acid in the mix so be careful. Google should probably find it. Everything sounds expensive over there.
24th Feb 2017, 05:54 PM #4Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
I've been meaning to try the copper sulphate layout solution, another thought is to buy some cheap bottles of printer ink refill http://www.ebay.com.au/itm/4Pcs-100m...Vme35hizlhobjw
I suppose with all three colours, (Cyan, Magenta and yellow) you could make any colour layout fluid you like.
Ben
24th Feb 2017, 11:53 PM #5
I never found it in Australia either.
I bought dykem, from Amazon, and used shipitto for mail forwarding when I bought it I also purchased some paint marker pens.
https://www.amazon.com/Dykem-80300-S...m+layout+fluid
Weirdly, they refused to ship the paint marker pens, claiming they were illegal to post because they contained flammable liquid, but they shipped the dykem without a murmur.
Here are the offending pens
https://www.amazon.com/WHITE-FINE-DY.../dp/B00DVTM8T8
25th Feb 2017, 10:14 AM #6Most Valued Member
- 4,255
I use the Dy-Mark paint markers...seem to work Ok but not having any others I havent compared.
Have got 4 tins of red and blue Dykem on their way from the US via Shipito. ..need a lot as I am gunna paint the town red...lol...na will try and off load some to someone..Michael G needs a tin for the thread gauge he made for me
Have you compared the DyMark to the Dykem layout blue's Ray and if so what was opinion?
25th Feb 2017, 10:19 AM #7
What is the difference between Dykem and Dymark?
I bought 1lts Dymark from General Tools 12 months ago.
No price on the bottle. Can't remember how much it cost.
Sent from my D6683 using Tapatalk
25th Feb 2017, 10:29 AM #8
I have tried DyMark Ink in a spray can, but it deposits quite a thick layer and can peel off. I use bearing blue for any marking out I do which is not much.
25th Feb 2017, 10:36 AM #9
I did a rough sort of comparison a while back, the bottom line is that Dykem is different, has a sort of acetate smell, Dymark has a sort of solvent smell. The Dykem seems to hold a line better and stands up better under coolant.
But reality is, they aren't all that much different, given the choice I'd go Dykem, but have no problem using Dymark if that's all I've got.
25th Feb 2017, 11:49 AM #10
I originally bought Starett mark out dye, I found it is very thick, it flakes off and what doesn't flack off is very hard to remove.
26th Feb 2017, 03:27 PM #11
Yes I know its not DyKem but whats the difference between it and Dymark?
From Google
STAIN LAYOUT DYMARK BLUE 1 LITRE. Can be had in black,green and other colours.
Part No. 00279242
Blackwoods https://www.blackwoods.com.au/part/0...k-blue-1-litre
currently $25 & change
27th Feb 2017, 08:26 PM #12
I have changed to simple permanent markers , mistakes are easy to correct and only need to put a strip about 1/2" wide where the marking lines are going to be placed .
And they are cheap.
9th Mar 2017, 11:24 AM #13Most Valued Member
- 4,255
getting this stuff to Australia is a headache
using SHIPITO and selecting AusPost resulted in being told that that they could not ship goods to aust.
So reselected FedEx.
Had to do this twice as co I bought thru on Amazon shipped it in two different parcels ( unknown to me) both of which arrived on different days. Thinking all was in one box I arranged freight for the first box...if I 'd known I could have consolidated and probably saved on freight to Aust?
Received an email from Shipito this morning requesting (on behalf of Fedex) what the goods exactly were. So sent back an email explaining it was an ink for marking out and link to Travers Tools.
then 10mins ago a call from Fedex again asking what it is. I explained it was engineers layout blue (or red). She was obviously in Australia as she had looked up Blackwoods site and saw Dymark and asked if it was that . I said yeah same stuff really but different ..."Dykem is better" I said. She said she will send back the info .... Told her about other co-note while I was at it, so hopefully no more emails or calls from shipito and Fedex
If it gets here, I hope its worth it!!!!
almost as bad as trying to import firearms stuff
Looking for a supplier of Dykem Steel Blue
By RayG in forum METALWORK GENERALReplies: 51Last Post: 23rd Oct 2015, 07:03 PM -
What's up with my link
By HappyHammer in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 23Last Post: 14th Aug 2005, 11:09 PM
