Results 1 to 15 of 32
10th Feb 2017, 08:51 PM #1Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
Cheap eBay Collet Chuck & Collets?
G'day
Does anybody have experience with the cheap, Chinese ER32 collet chucks and collets found on eBay?
ER32 MT2 Collet Chuck Morse Taper Toolholder Milling Rod Straight Chuck Holder | eBay
and
NEW ER32 19 PCS SPRING COLLETS SET 2-20mm ER32 Collet For CNC Engraving Machine | eBay
I'm setting up my Taiwanese Lantaine Lam lathe to do some light milling work with a vertical mill slide I picked up off Gumtree last week, my lathe came with a MT4 1/2 spindle sleeve adapter that reduces down to an MT2, the plan is to use the sleeve with a MT2 collet chuck and a drawbar to hold my end mills and such.
Any hard earned prior experience with these Chinese collet chucks and collets would be appreciated.
Thanks,
Ben
10th Feb 2017, 09:19 PM #2Pink 10EE owner
- 6,216
They are fine in my experience.
10th Feb 2017, 09:29 PM #3
Hi Ben,
I have a set. Mine is ER32 on an MT3 collet holder with a 12 mm draw bar thread in the tail. I forget without going to look but the collet set has 13 or 15 collets, all nicely boxed in yellow plastic containers. I keep threatening to make a rack for them but since I've only actually used two of them, I've not gotten around to it. Their fine.Best Regards:
10th Feb 2017, 09:31 PM #4Most Valued Member
- Australia east coast
- 2,713
Paid $65 for my set of ER32 collets, IIRC. No complaints, they work fine.
Cost me $130 I think for a full set of ER40 collets also Chinese origin. Also no complaints.
PDW
10th Feb 2017, 09:37 PM #5Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
Thanks fellas I'll place an order, I'll grab some carbide end mills while I'm at it, apparently they're not bad quality either
10th Feb 2017, 10:55 PM #6Golden Member
- Vic
- 48
- 544
I have the Chinese set on the left and Taiwanese (supposed to be better) on the right.
The Chinese set appears to be ok for what I do, I normally use them on the lathe and use the Taiwanese on the milling machine
11th Feb 2017, 07:20 PM #7Member
- Jul 2013
- BRISBANE BAYSIDE
- 90
From your description, it appears that your lathe headstock spindle has an MT4 taper. Wouldn't it be better to buy an MT4 ER32 chuck and cut out the intermediate sleeve which can only be another potential source of misalignment. They are certainly available on ebay, although maybe not from the seller you linked. The MT4 chuck would certainly be a stronger unit than one with an MT2 taper, and for milling I would be looking for the strongest unit possible.
I ran one of these on my lathe for milling before I bought a milling machine, although my lathe has an MT5 spindle taper, so had to use an MT5/MT4 sleeve. MT4 ER32 chuck is the largest made.
Still use it for turning when the work is up to 20mm dia.
Alan.
11th Feb 2017, 08:30 PM #8Most Valued Member
- Jun 2012
- SA
- 1,649
Agree. Morse sleeve/adapters are not a great idea, unless you are desperate or need to conserve pennies and use the chuck in several different sized machines. They all have two chances of introducing run out.
ER32 chucks are readily available in Morse 5 - generally more expensive though.
But at least you tried.
11th Feb 2017, 10:01 PM #9Member
- Jul 2013
- BRISBANE BAYSIDE
- 90
You are right Rob, it seems they are around but they certainly are expensive. Probably why CTC doesn't offer them above MT4. But then CTC appear to not be worth dealing with any more since the shift into Europe. I didn't realize that you could actually get them in MT5 when I bought mine some years back.
Alan.
11th Feb 2017, 11:35 PM #10Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
I wish it was that simple, my lathe spindle has an MT (4-1/2), I did some searching around online for a collet chuck in the half size but came up empty, I figured the next best (and cheapest) option was to use the sleeve and an MT2 collet chuck, I would definitely prefer a more rigid set up but I figured for the light hobby work I'm doing, if I take light cuts and the run out isn't too bad, it would be OK.
Ben
12th Feb 2017, 08:59 AM #11Golden Member
- Vic
- 48
- 544
Maybe make something like this Ben?
//metalworkforums.com/f189/t199...r-hercus-260-a
//metalworkforums.com/f303/t198...ghlight=collet
//metalworkforums.com/f65/t1916...ghlight=collet
12th Feb 2017, 09:02 AM #12Most Valued Member
- Jun 2012
- SA
- 1,649
They have always been available, but mainly from specialist/industrial machine tooling suppliers - and very expensive (but top quality) compared to other options.
Only in recent years have they appeared on Ebay at more reasonable prices. But then again, compared to the price of a good chuck, they are affordable.
I would ditch that sleeve and get one if I was you. It's worth it just for peace of mind.
12th Feb 2017, 09:52 AM #13
Well I have done it again.....I have been looking with interest for some time now at whether I should get a set of Collets to add to the versatility of the 100 year old Metal Lathe and my home made wood lathe. I had ear marked a set of Collets and a MT 2 Collet Chuck and been seeing them in the Watch List over the last 3 months or so. Well seeing this thread and a reminder note from Ebay, I put the order in last night.
Reading these Forums since 2009 has increased my "Tool Acquisition Program" by a significant amount. With these new tools I have been able to "Tinkter" with new interest in things. When I am gone someone will have some fun either selling my gear or "Tinker" them selvesJust do it!
Kind regards Rod
12th Feb 2017, 10:02 AM #14Banned
- Feb 2015
- Oz
- 73
- 459
What is the benefit in using a collet rather than just chucking the end mill like I do?
12th Feb 2017, 12:35 PM #15Most Valued Member
- Jun 2012
- SA
- 1,649
Collets can grip ANY round item, including threaded round, mills with flats, and much more tightly than a chuck.
They will not damage threaded components like chuck jaws will.
They will not tear up mills or drill ends like a chuck can do, if they slip.
They are quick to use and very accurate.
Once you use collets, you will never go back to a chuck on a job of suitable size.
collets : to chuck or not to chuck
By steamingbill in forum METALWORK GENERALReplies: 4Last Post: 26th Jul 2014, 10:17 PM -
WIP - Collet Chuck
By Vernonv in forum METALWORK GENERALReplies: 19Last Post: 23rd Jan 2011, 11:53 AM -
cheap HM52 on ebay
By eskimo in forum METALWORK GENERALReplies: 1Last Post: 29th Nov 2010, 01:01 PM -
Cheap Sheraton on Ebay
By nexusone in forum METALWORK GENERALReplies: 0Last Post: 16th Nov 2008, 07:02 PM -
Cheap Hercus on Ebay - $250 BIN
By hux in forum METALWORK GENERALReplies: 4Last Post: 5th Feb 2008, 08:34 AM
