Results 1 to 15 of 28
Thread: Steering shaft worm thread
6th Feb 2017, 10:50 PM #1Banned
- Aug 2015
- QLD
- 735
How to make it and what to make it from ?
**edit* If done in one piece most of the shaft is fairly straight forward machining. The variable pitch thread is a problem for my YouTube machinist education. **
The pictured (borrowed) steering shaft is from a 1950's vehicle. The worm section of the shaft files harder then HRC65 whilst the main shaft files metal with a HRC40. Sections joined by some form of press welding. Looking at the pictures the tool marks of the milling of the worm thread is easy to see.
I've done the usual Google and had a ganda at PM with no luck apart from how-to variable thread CNC programming.
I don't have CNC so thoughts anyone?
6th Feb 2017, 11:13 PM #2Most Valued Member
- 5,942
Where I worked once, we made irrigation equipment that had a screw thread that was done on a milling machine. It was similar to what you're looking for.
Would it be possible to screw cut it on a lathe, then get it hardened?
6th Feb 2017, 11:24 PM #3Banned
- Aug 2015
- QLD
- 735
I fergot to add the variable pitch reference to the title.
First post edited.
6th Feb 2017, 11:34 PM #4Banned
- Aug 2015
- QLD
- 735
7th Feb 2017, 06:56 AM #5Philomath in training
- 6,540
If I had to I think I'd cut it as a helix on the mill (vertical head but driving the dividing head from the table), first cutting one side of the groove and then resetting back to the same starting point and cutting the other side of the groove with a slightly different lead so the worm changed.
What does the driven part look like though? It's not just wear?
Without the universal dividing head it may be you have to step the profile out (that is, rotate x degrees, advance longitudinally y mm). After that, clean up with a file.
MichaelLast edited by Michael G; 7th Feb 2017 at 05:12 PM. Reason: fixed mistake
7th Feb 2017, 01:05 PM #6Most Valued Member
- Australia east coast
- 2,713
7th Feb 2017, 03:48 PM #7China
- Dec 2005
- South Australia
- 1,656
I am no expert in this, although I have had steering worms rebuilt on non replaceable items, the company I used built up the worn surface and then reground on a grinder that was equipped with a pattern follower
7th Feb 2017, 05:45 PM #8Banned
- Aug 2015
- QLD
- 735
7th Feb 2017, 05:48 PM #9Banned
- Aug 2015
- QLD
- 735
7th Feb 2017, 08:07 PM #10Pink 10EE owner
- 6,216
Possiblymade on some special machine with non circular gears.
7th Feb 2017, 08:07 PM #11Most Valued Member
- 5,942
What is the part from, besides a steering box, someone may know where to find a good one? To look at getting it repaired, look up hard chroming, they can build up all sorts of worn shafts and gears.
8th Feb 2017, 11:04 AM #12Banned
- Aug 2015
- QLD
- 735
I source vehicles and components from all around Oz so a useable shaft will come up eventually. Though, I keep looking at the shaft and thinking how hard can it be to make me own.
Getting some good hits with the "hard chrome plating" search. Even a video of a machine shop in Brisbane - https://m.youtube.com/channel/UCsVIiQtVgyH8rnSrX_Ja9-g
8th Feb 2017, 11:15 AM #13Banned
- Aug 2015
- QLD
- 735
8th Feb 2017, 11:42 AM #14Philomath in training
- 6,540
If the pitch was uniform it would be easy to do as a spiral milling job, and I think the tool marks in the bottom of the grooves support that idea. First photo is post one suggests it is a uniform pitch worm, but the last pitch is worn.
8th Feb 2017, 12:19 PM #15Golden Member
- Mar 2009
- 54
- 825
In a modern shop, servo controlled lead screw with feedback to the spindle, yeah I know that's pretty much NC.
Old school, rack and pinion driven lead screw controlled by a cam driven from spindle? Complex to set up and not easy to change but I'm thinking this was produced on a dedicated machine.
I'm trying to work out the benefit of the variable pitch unless the steering is lock to lock in one revolution.
Is this from a racing box of some sort?
Greg.
Steering Wheel Restoration
By Goggomobile in forum AUTO RESTORATIONReplies: 8Last Post: 30th Aug 2021, 12:32 AM -
Advice needed - double start worm thread
By morrisman in forum METALWORK GENERALReplies: 4Last Post: 13th Jun 2013, 08:48 AM -
Steering gear cutters?
By Ash240 in forum METALWORK GENERALReplies: 6Last Post: 24th May 2012, 09:53 AM -
Self-steering trailers
By joe greiner in forum TRAILERS & OTHER FABRICATED STUFFReplies: 5Last Post: 12th Apr 2010, 06:06 PM -
Restoring a bronze motor boat steering wheel
By gordonwindeyer in forum METALWORK GENERALReplies: 8Last Post: 5th Oct 2009, 03:43 PM
