Results 1 to 3 of 3
Thread: Stand Off's
25th Jan 2017, 07:33 AM #1
Stand Off's
I came across an odd thread combination this afternoon. I needed to support a PCB off a alloy box chassis plate, so I grabbed four brass hex stand off pillars, salvaged from a scrap computer case. No problem there, M3 internal thread. At this point I assumed M4 external thread. So after drilling and threading four holes, I found that the pillars only screwed in a couple of turns before pulling out ??? When I tried to tighten them they just spun in the hole.
After checking the external threads on the pillars, I discovered that they actually were #6 x 32 UNC. Fortunately moving down 1/4" inch and redrilling and tapping #6 x 32 allowed me to salvage the alloy box.
A group picture of the stand off's and a die I used to confirm the thread.
Checking some other brass stand off pillars produced several other combinations of internal and external threads. I found M3.5 internal / 6 x 32 external, M3.5 with M4, 4BA with M4, and some with threads I couldn't identify.Best Regards:
25th Jan 2017, 07:51 AM #2Golden Member
- Apr 2009
- Ballina N.S.W.
- 644
Hi BaronJ,
I have been dismantling old computers and printers for years and you are right they use a real mix of threads both unc and metric especially on the older ones. I just broke down two big commercial printers and found all the screws were metric 99% of them were 3mm ones. They were of Japanese origin so it was not a surprise, As you know they are a great source of ground rods, between these two I recovered 53 rods from 5mm to 16mm in diameter and over 200 short metric screws.
Bob
25th Jan 2017, 10:24 PM #3
Hi Bob,
I've been doing the same salvaging stuff. It just supprised me a little to find such a variation on a single part.Best Regards:
lathe stand
By welder in forum METALWORK GENERALReplies: 22Last Post: 7th Oct 2012, 11:49 PM -
Micrometer Stand
By Blu_Rock in forum METALWORK GENERALReplies: 10Last Post: 3rd Apr 2012, 11:20 PM -
Lathe Stand
By slhouetteV8 in forum METALWORK GENERALReplies: 23Last Post: 20th Feb 2012, 05:29 PM -
lathe stand
By welder in forum METALWORK GENERALReplies: 3Last Post: 4th Aug 2011, 01:15 AM -
Two grinder stand
By Andy Mac in forum METALWORK GENERALReplies: 9Last Post: 7th Apr 2011, 11:13 PM
