Results 1 to 7 of 7
Thread: AL330A Cross Slide Removal Help!
24th Jan 2017, 09:23 PM #1Novice
- Aug 2009
- Sydney.
- 16
I need to remove the cross slide from my Hafco
AL330A lathe and hoped that some body may have already done this.
I think that I just have to undo the front and rear Gibb screws and remove the Gibb. Then undo the two Hex head screws that secure the Leadscrew nut.
This should allow me to just lift off the cross slide.
There is a small hex set screw between the two Leadscrew nut securing screws and this is what concerns me. I believe it alters Leadscrew backlash but don't know how the adjustment is accomplished.
Has anyone been through this procedure before?
I would be grateful for any tips or advice.
25th Jan 2017, 12:25 AM #2Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
Can you feed the cross slide all the way in until it disengages the leadscrew and slide it off the back in one piece?
25th Jan 2017, 12:38 AM #3Senior Member
- Apr 2013
- Toowoomba Qld
- 401
remove back sheet metal splash cover (need clearance)
remove gib (if feeling lazy you can even leave the gib in place but it's tighter to move)
wind the cross slide til the nut runs out of thread
slide off the rest of the way and lift it off.
Takes longer to remove the sheet metal guard then to do the rest.
Have done this several times on mine as I remade some compound nuts
Wayne
25th Jan 2017, 11:37 AM #4Novice
- Aug 2009
- Sydney.
- 16
Thanks for the prompt replies.
I will remove the splash guard and wind the cross slide all the way off.
In the parts list it refers to a "Wedge" that is adjusted/pushed by the little hex set screw. The wedge appears to push apart the split leadscrew nut.
Have you used this to adjust backlash in the cross slide nut?
Wayne, I am curious as to why you needed to remove the cross slide to remake the compound nut. Was the nut on your AL330A worn?
I want to remove the crosss slide to fit a Threading Stop similar to the project
described here..
Birmingham 12×36 Lathe | Dezign Shack Blog
Thanks again
25th Jan 2017, 11:06 PM #5Senior Member
- Apr 2013
- Toowoomba Qld
- 401
26th Jan 2017, 09:33 AM #6Diamond Member
- N.W.Tasmania
- 1,407
Nice looking job you did there MS
30th Mar 2017, 11:14 PM #7human termite
- Jul 2007
- sandstone point queensland
- 69
- 182
just back that small screw right off then you can just lift the cross slide off by tilting it on its side,there is a small wedge that goes between the leadscrews, this is for tension/backlash,there are two alan screws on the other side (left) back them off also, make it come out easier,when you put it back together and all in place tighten them back up ,then the tensioning one on the opposite side, then the top tensioning one,its acctually an easy job once you have done it,why are you taking it off ?(did you screw it ll the way out now it wont come back,if so you can put your fingers underneath and position the block again and bobs your uncle
Cross slide reconditioning
By argeng in forum METALWORK GENERALReplies: 4Last Post: 5th Jan 2014, 07:46 PM -
Cross slide scraping
By Stustoys in forum METALWORK GENERALReplies: 358Last Post: 13th Jan 2013, 10:08 PM -
Cross-slide play
By jack620 in forum METALWORK GENERALReplies: 23Last Post: 19th May 2012, 07:50 AM -
Cross Slide Nut
By raypat in forum METALWORK GENERALReplies: 19Last Post: 9th Dec 2011, 01:41 AM -
sheraton A cross slide nut
By danielhobby in forum THE HERCUS AREAReplies: 5Last Post: 21st Apr 2011, 07:50 PM
