Results 1 to 15 of 34
Thread: Drill Geometry
20th Jan 2017, 12:00 PM #1Senior Member
- Jul 2007
- 332
Drill Geometry
Purchased a set of Dormer UK metric drill bits when passing through Singapore, but did not look at then closely at the time. However now I see the secondary clearance angle looks to be excessive, but maybe this is just the new trend. So wondering if anyone else has seen such and any comments / suggestions. First photo (I hope) is relative to an off the shelf drill bit. Thanks, Alan.
20th Jan 2017, 12:20 PM #2
Yes I have. Milwalkee Thunderbolts, and another Milwalkee set I purchased a couple of years ago. I believe they have a 135 deg cutting angle. They also have the split point / 4 facet grind. I have used them almost exclusively since I bought them. Mainly because they are complete sets of drills capable of drilling stainless steel and alloy steels.
Some years ago I read quite a bit of information regarding the drill cutting angle and there were a number of people who felt that the larger angle was beneficial to cutting as it provided a shorter length cutting edge and so less required effort. It was also felt that the 118 deg angle was just a random value. Maybe just a happy medium.
20th Jan 2017, 12:48 PM #3
I do a far amount of drill work on small stainless, diameters -mainly 304.
I use 4 facet 135 degree drill bits solely for stainless and will not use 118 bits ever again on stainless. Couple with the correct operating specs and a modicum of common sense and you will have no trouble.
20th Jan 2017, 12:59 PM #4Philomath in training
- 6,542
There is a fancy name for that (point splitting). Really, the material behind the cutting edge only supports the edge so can be relieved quite a lot.
20th Jan 2017, 02:42 PM #5
Hi C-47,
I would not see it as a problem. This sort of split point is fairly common and the exact angle of the relief and amount of material removed seems to vary by manufacturer according to their marketing blurb. The 135 or 140 degree angle grinds seem to be good for harder materials. The 118 degree points seem good for softer stuff. TiN coating also helps with harder stuff and reducing wear.
Lathes - Sherline 4410 CNC
20th Jan 2017, 06:33 PM #6
I bought a set of Sutton Viper drills a couple of years ago the had the same tips.
20th Jan 2017, 06:51 PM #7Senior Member
- Jan 2012
- Hinchinbrook
- 112
I can see no reason for that sort of clearance behind the lips other than marketing, and a speedy replacement of the bit. As soon as you have sharpened the drill once or twice you will need to grind back a diameter or more just to re-establish a new cutting edge.
Cheers Phil
20th Jan 2017, 09:07 PM #8Senior Member
- Jul 2007
- 332
Thanks to all for the responses, I won't have to bin them now . Maybe I need to visit the tool shops more often to see what's trending, sure I can explain that to the money minder. Alan.
20th Jan 2017, 09:29 PM #9Pink 10EE owner
- 6,216
20th Jan 2017, 09:42 PM #10Most Valued Member
- Australia east coast
- 2,713
No you don't. Either you re-grind them to the same angles or you grind them to a traditional constant backoff angle. Whichever works for you. I do both depending on what I want to do. The split points tend to self-centre a bit better than the smooth relief grinds IME.
PDW
20th Jan 2017, 09:49 PM #11Most Valued Member
- Oct 2007
- 3,112
Phil, as Michael said, that grind is a way to achieve a split point. I have some that are ground that way and it seems to be the trend these days. Splitting the point is not a marketing product and is definitely noticeably better, especially to start. I split the points another way, but the effect is the same.
There's also no need to throw them away if they need sharpening, you will just lode the point splitting unless you regrind it also.
Alan, Singapore + Dormer, I bet I know where you got them
20th Jan 2017, 09:59 PM #12
I agree with all the points made here, I will add that, I now grind all my drills four facet split point, particularly since I made John Moran's 4 - 6 Facet drill grinder. One other comment is that I grind both 118 and 125 degree tip angles. I find that the sharper angle is better for harder materials.Best Regards:
21st Jan 2017, 09:02 AM #13Golden Member
- Apr 2009
- Ballina N.S.W.
- 644
Pete F
Yes I think I know the source as well, I hope that Alan's drills are the real thing not like the fake Presto ones I brought a few years ago from the same place. I have an assortment of Dormer taps,end mills from the same supplier and they are all good quality.Are Dormer products still made in UK.The extra clearance is supposed to reduce the downward pressure when drilling especially on larger diameter drills.I agree with Baron J a four facet grind with a split point is a joy to use.
Bob
21st Jan 2017, 12:25 PM #14Senior Member
- Jul 2007
- 332
Bob and Pete,
I reckon probably the same place on Rowell Rd, have always had good stuff from there, so far anyway. When I brought this lot was offered made in UK (coated) or for a bit less (un-coated) made in Brazil, I chose the former as previous stuff made there has been good. Alan.
21st Jan 2017, 11:00 PM #15
I don't think that Dormer make anything in the UK any more ! It seems to come from Brazil and Czechoslovakia
http://www.dormerpramet.com/en-gb/co...our-production
The drills used to be made in Shefield. Somewhere I still have a couple of long (12") X (1/8") inch split point specials that they made me, for a particular deep hole job.
I recall that compared to todays prices, they weren't all that expensive either.Best Regards:
parting tool geometry
By brendanh in forum METALWORK GENERALReplies: 19Last Post: 25th May 2015, 06:58 PM -
Drill Sharpening Jig Geometry
By Burnsy in forum METALWORK GENERALReplies: 4Last Post: 28th Aug 2014, 08:09 PM -
TIG tungsten electrode tip geometry - science vs wisdom?
By blouis79 in forum WELDINGReplies: 11Last Post: 9th Nov 2013, 07:59 AM -
Drill Point Drill
By Penpal in forum METALWORK GENERALReplies: 11Last Post: 18th Jan 2007, 10:22 AM
