Results 1 to 15 of 19
Thread: Grinding Wheel
9th Jan 2017, 09:45 AM #1
Grinding Wheel
Can anyone suggest where to obtain one of this type of grinding wheel at a reasonable price?
I am looking for one to use with my drill bit sharpening attachment. It will also be used for the Eccentric Sharpening Tool when I get it finished. I would also appreciate info on which type and grade would be suitable.
9th Jan 2017, 01:53 PM #2Philomath in training
- 6,541
Here in Adelaide there is a place called Weber Abrasives (in Welland I think) that should be able to help.
Normally the rule is 'hard material, soft wheel' so if you explain to them it is for drill bits they should be able to recommend a suitable grade. I have a spare grinding booklet that you can have if that helps too.
What OD are you looking for? Pete had a few wheels at one stage (I grabbed some) so there may be one there that suits.
9th Jan 2017, 03:45 PM #3
9th Jan 2017, 06:17 PM #4
Tw
This is worth a try , they have branches in various places
Dandenong
10th Jan 2017, 12:18 AM #5Novice
- Jul 2008
- Sydney Australia
- 76
- 22
Hi,
Blackwoods lists the type 6 straight cup wheel in general purpose grades
https://www.blackwoods.com.au/search...pe-6/302022918
I'd get about a 38A60-KVBE, similar to your photo.
10th Jan 2017, 01:58 AM #6
Hi Dean,
I use these people
Sanding Tools & Abrasive Equipment | AbTec
They actually manufacture stuff as well and are very helpfull.
But note I'm in the UK.Best Regards:
10th Jan 2017, 07:54 AM #7
12th Jan 2017, 10:44 AM #8
13th Jan 2017, 11:30 AM #9Senior Member
- Feb 2016
- NSW
- 117
That's not a problem, Blackwoods now allow you to register an account as an individual, without an ABN. Makes life much easier.
14th Jan 2017, 09:49 AM #10
The wheel I am looking at is
https://www.blackwoods.com.au/part/0...m-38a46f12vbep
This is the only 180mm wheel they have listed. Other than that one it is back to 150mm. Any issues with this one? I know very little about the codes for these wheels (or any others). The 826mm is 82.6mm. Can someone provide actual sizes from this code? I know OD is 180mm.
The web page has a drawing. If it was shown about 4 times the size, just maybe it might be readable. I rang and asked. They did not know and were going to find out and email me back. Nothing yet. The Saint-Gobain web site (owners of Norton) and a Norton web site seem to be under construction. All they provide is the very annoying "Look at the sort of stuff we carry", dead end pages.
I will check Michael's suggestion next week. I will be going to Adelaide soon.
14th Jan 2017, 11:02 AM #11Philomath in training
- 6,541
I have a booklet that you can have that gives the basics of wheel codes. However,
38A46F12VBEP
is using 38A abrasive ( Al oxide - typically for sharpening)
46 grit size
F bond (softish)
12 denotes structure
V is a vitrified bond and the BEP is a manufacturer's class of bond.
14th Jan 2017, 07:27 PM #12
Thanks Michael. Any idea of the sizes. I want to make sure the face is wide enough for my purposes. At that price I don't want to take any chances.
14th Jan 2017, 10:34 PM #13Philomath in training
- 6,541
To start with, I think Blackwoods have a typo on their catalogue page. That last number should be 32 not 82...
This is what I think they are offering -
Hope that helps.
15th Jan 2017, 08:16 AM #14Senior Member
- May 2015
- Richmond
- 214
Added to Michael's info: "P" is for a porous bond. Looks like a bit of swiss cheese but holes not as big! Gives better cooling on some applications.
Dean. Look for a "Recessed 1 side" wheel rather than a Cup wheel. The recessed wheel gives a wider rim than a cup wheel which will suit your application better.
15th Jan 2017, 09:38 AM #15
Thanks Michael. That makes more sense. That 82.60 threw me. Where did you get the 16mm face width from?
OldRustyToolie, Thanks for that advice, not. Just when I thought I had the right wheel and you go and poke holes in it. Seriously tho, I am not sure if the 16mm width on that wheel would be sufficient. I will have another look.
Grinding wheel advice
By caskwarrior in forum METALWORK GENERALReplies: 1Last Post: 18th Dec 2016, 08:53 PM -
Grinding Wheel Runout
By Anorak Bob in forum METALWORK GENERALReplies: 38Last Post: 23rd Aug 2011, 05:49 PM -
Which Grinding Wheel For Grinding Tungsten Electrodes
By Metal Head in forum WELDINGReplies: 14Last Post: 8th Aug 2009, 02:23 PM -
Grinding wheel supplier?
By Greg Q in forum METALWORK GENERALReplies: 11Last Post: 23rd Jun 2008, 02:56 PM -
Lap grinding wheel
By ROB NZ in forum METALWORK GENERALReplies: 6Last Post: 20th Jan 2008, 06:42 AM
