Results 16 to 30 of 46
Thread: Drill press speed optimisation
28th Dec 2016, 09:21 PM #16Intermediate Member
- Jan 2011
- South Australia
- 29
Here's a brief video of a belt tensioner I made for my Waldown bench drill several years ago.
It is very easy to operate and has proven completely reliable and trouble free.
BTW I fitted 3ph motor and VFD at the same time to solve my speed selection issues.
Here's a video of the drill pushing a 1" bit through 10mm MS plate
28th Dec 2016, 09:52 PM #17Most Valued Member
Richo, nice work, a bit rough though, no knob on the end. What happens when the belt stretches or is replaced with a slightly shorter belt? Is there any other adjustment available?
28th Dec 2016, 10:27 PM #18Intermediate Member
- Jan 2011
- South Australia
- 29
Regarding the knob, I have no excuse - just laziness In addition to the over-centre action, there are actually 2 other adjustments possible for belt tension.Its a bit hard to see, but the front end of the other over-centre unit is slotted to give about 1" of adjustment.This was designed to be the primary method for setting the belt tension resulting from the over-centre action.For even more adjustment, the motor mount casting on the end of the radial arm could be moved further away from the quill.However, I think a belt change would be preferred rather than doing this.The new belt I installed when fitting the device in early 2012 is still running at a good tension and no adjustment has been needed so far.
NB: Should note that I make a practice of leaving the belt loose when the machine is not in use.
13th Jul 2021, 08:57 PM #19Philomath in training
It's taken 4 1/2 years, but I've finally re-worked my Waldown - it is now a 12 speed unit with no gaps in the speed range (but basically the same range as before). All I have to do now is fix up a guard to fit (needs 'stretching' around 20mm)
The motor and spindle pulleys are straight stepped pulleys but the intermediate is a two piece design and also has bearings in it. I've managed to juggle the sizes so that the belts have a uniform tension (no loose belts at certain speeds as Waldowns can do), and none of that annoying 'take all the belts off' to change for the high speeds.
Thanks to Kryn for finding the Al at a good price and to Eric for helping slice the stock to size.
15th Jul 2021, 08:57 AM #20Member
- May 2021
- Sunshine Coast QLD
- 62
Impressive!!
I have 2 words - “Nova Voyager”.
https://www.carbatec.com.au/nova-dvr...10&SearchPos=1
On one hand, this seems my dream drill. (I use my drill press a lot, and I’m always changing belt position.)
On the other, it’s $3000, and still drills holes.
Pretty sure I’m getting one. One day.
15th Jul 2021, 09:13 AM #21Member: Blue and white apron brigade
I've had a vector drive VFD on my drill press (1.5HP motor and VFD) for a few years now.
I've been running the spindle between 150 and 1500 rpm mot of the time on the same belt position with no problems.
Even with prolonged low rpm drilling there has been no overheating problems.
I have changed the belt position only a couple of times during that period.
15th Jul 2021, 09:24 AM #22Most Valued Member
Echoing what Bob said. A VFD and 3 phase motor will set you back a lot less than $3000. You can even dispense with the intermediate pulley.
15th Jul 2021, 09:45 AM #23Member: Blue and white apron brigade
I like the dispensation of the intermediate pulley.
Comparisons between a $120 VFD and say $200 3P motor to get variable speed , and with the $3000 Nova can be misleading.
The Nova also has almost twice the Quill travel and a bunch of other features that few standard drill presses.
Whether the the additional features are worth the the extra $$ is perhaps a separate question.
15th Jul 2021, 10:12 AM #24Most Valued Member
15th Jul 2021, 04:55 PM #25Diamond Member
- Aug 2006
- 1,106
Also the Nova only can take bits up to MT2, seems sorta useless to me for that sorta $$$
15th Jul 2021, 10:36 PM #26Diamond Member
- N.W.Tasmania
- 1,407
Given the choice, for that sort of money I would prefer to have a powered downfeed.
17th Jul 2021, 10:34 AM #27Member
- May 2021
- 62
I think the Nova is primarily a woodworking drill.
Some of the features that really appeal to me (mainly metal work):
High speeds - for small drills.
Quick and easy speed changes.
Smooth running.
Electronic depth stop.
But I need a lathe first.
17th Jul 2021, 11:41 AM #28Member: Blue and white apron brigade
17th Jul 2021, 12:21 PM #29Member
- May 2021
- 62
Tapping assist function
Any tips on holding a thread tap (M12 in this case) 4 side square, in a 3 jaw PD drill chuck?
I’m trying to ensure I tap “square” in my job.
I gripped it further down on the round bit, but it turns in the chuck.
I’m turning the chuck by hand - just using it for “square”.
The large keyless chuck with the jaws retracted on the back of the tap wrench is better than nothing…..
17th Jul 2021, 01:04 PM #30Member: Blue and white apron brigade
GMF Betts 12 Speed Drill Press Tidy Up
By Burnsy in forum METALWORK GENERALReplies: 36Last Post: 8th Dec 2014, 12:40 PM -
Variable speed drill press - Old style
By Michael G in forum METALWORK GENERALReplies: 11Last Post: 14th Nov 2014, 06:50 PM -
Waldown 8SN drill press change belt/ speed questions
By thorens in forum METALWORK GENERALReplies: 8Last Post: 15th Sep 2013, 11:53 PM -
Switching 2 speed motor for drill press
By Bryan in forum METALWORK GENERALReplies: 3Last Post: 28th Dec 2011, 07:05 PM
