Results 1 to 7 of 7
9th Dec 2016, 07:25 AM #1Most Valued Member
Is this really a surface grinder?
Hi all,
Was looking through ebay this morning and saw this "surface grinder"
I have seen t&c grinders attempted to be sold as SG before so I'm wondering if this really is a SG, although it's probably not a t&c grinder anyway. Unless I have missed something, it seems to be direct drive from the motor, is this a normal practise with some makes for thier SG?
The belt guard has me puzzled too. If it's originally direct drive, where would that (what appears to be a) belt guard go? It all looks original. Also, the wheel is very close to the body, severely limiting the reach of the wheel.
SURFACE GRINDER | eBay
9th Dec 2016, 07:54 AM #2Senior Member
- Jan 2012
- Hinchinbrook
- 112
I've seen a very similar machine in a local shop here. They use it for surfacing. I dont think thats the correct wheel for that machine. Looks like the guard is designed to go over the grinding wheel and workpiece. pics 2 & 3 you can see the mounting bolts. With the open end maybe they had an extractor connected to it? Be a bastard to fit the guard and then have to work underneath it to fit the wheel.
Cheers Phil
9th Dec 2016, 08:03 AM #3Most Valued Member
In the normal sense, I'm voting NO
I don't have an issue with the direct drive motor, but with the current wheel it has almost no Y travel. (even if the wheel dia is large enough to clear the motor, which I'm not so sure it is, there still isn't much travel before the work hits the column)
The guard looks very wide so maybe its was meant to use a cup wheel and be vertical surface grinder(though a horizontal one lol)
I cant help but think they had something else in mind, but I guess is would grind "a surface", all be it a long narrow one.
Hope someone comes along to clear things up.
9th Dec 2016, 08:42 AM #4Senior Member
- Jun 2012
- melbourne
- 341
Its hard to see where it gets its y travel from right enough. There's another one here so I think its legite
Wanted and Comments
I see on the back of the motor there is a dovetail, so does the whole motor move across to give the y axis?
9th Dec 2016, 09:12 AM #5Most Valued Member
That's my guess. I first thought the handwheel on the left of the motor was for Z but the second last picture shows the Z handwheel is under the table, which doesn't look to good as far as "taking a 1/10th off".
But as ever, if all you have is a bench grinder, it could well be a step forward.Last edited by Stustoys; 9th Dec 2016 at 03:25 PM. Reason: spelling
9th Dec 2016, 03:08 PM #6Golden Member
- Mar 2009
- 54
- 825
I think this is more of a tool grinder than a surface grinder.
There was a similar machine made by Parkinson at the Carr Gear Auction with a vertical spindle that was for sharpening gear planer cutters (see here about three quarters down in the photos, it was listed as a vertical tool lipping machine: //metalworkforums.com/f282/t199...rrow-june-21-a )
There is a discussion on a similar subject here: Parkson Surface Grinder - Page 2
If you go to post 25, picture number 2 shows what I believe is a very similar machine to the one listed on ebay.
Greg.
9th Dec 2016, 04:38 PM #7China
- Dec 2005
- South Australia
- 1,656
It is a machine knife grinder with the incorrect wheel fitted and it is missing it's chuck
Surface grinder.
By stix012 in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 1Last Post: 12th Jun 2016, 08:13 PM -
surface grinder
By allterrain50 in forum METALWORK GENERALReplies: 4Last Post: 27th Apr 2014, 04:06 PM -
surface grinder
By China in forum METALWORK GENERALReplies: 0Last Post: 19th Feb 2008, 12:48 AM -
surface grinder
By Arron in forum METALWORK GENERALReplies: 9Last Post: 16th Sep 2006, 11:43 AM -
Surface grinder
By steptoe in forum METALWORK GENERALReplies: 0Last Post: 10th Jun 2005, 12:21 PM
