Results 1 to 5 of 5
Thread: Adcock and Shipley Mill
19th Nov 2016, 02:33 PM #1
Anyone have any experience with an Adcock and Shipley 1ES Horizontal Mill, not a whole lot of info out there about them.
Shane
Got the square peg in the round hole, now can't get it out !!
19th Nov 2016, 05:50 PM #2Golden Member
- Jun 2004
- Kyabram. Vic
- 632
Yes; I have one in the workshop.
Looking at the $500 ebay offering are we?
It is classed as a production mill. The single handle on the right side front of the table operates the "cycle". The table starts from the right side position - engage handle to the left and table moves at quicker rate until it trips a preset dog. Milling feed speed (changeable gears) is automatically selected and cut is made until an adjustable end travel dog is engaged which activates rapids back to the table start position. Be careful around that handle as the feed motor runs constantly. There is provision for a lever lockout.
IMHO a nice sturdy small horizontal mill. The feed system would be a pain if you had a vertical head for it.
Manuals available at a price from Lathes UK
Ken
20th Nov 2016, 06:14 AM #3
Was pondering the one on Ebay, when you say production Mill how would that workout for just a home hobby workshop, saw the info on lathes UK, the one on Ebay looks like the one they describe as a general purpose Mill.
Can you tell me how big it is physically.
Cheers Shane.Shane
20th Nov 2016, 09:33 PM #4Golden Member
- Jun 2004
- Kyabram. Vic
- 632
The 1ES is the "production" mill as I said with the cycle as described above. That lever on the right side of the table activates the cycle with the table returning to the right on cycle completion. For horizontal milling I can see no problem; but if a vertical head (super rare in Aus) was to be used; it would be almost impossible to mill with the cross slide. With this system you basically take a preset length, full length cut and then change the job or advance the gear blank.
It has a 40 taper and weighs about 865kg. Mine has a large fibreglass chip tray and uses a working area of about 1750w X 1750D. This depth allows for the overhead slide to retract and the electric cabinet door to open.
Ken
28th Nov 2016, 09:07 PM #5Senior Member
- Nov 2012
- Blue Mtns
- 115
Yeah there was one where I worked years ago. Quite a neat compact hoz mill.
Wiring diagram for a Bridgeport by Adcock and Shipley Mill.
By Old Croc in forum METALWORK GENERALReplies: 4Last Post: 6th Nov 2014, 01:48 PM -
Adcock & Shipley Manual Wanted
By ChasWolf in forum METALWORK GENERALReplies: 1Last Post: 22nd Sep 2010, 07:32 PM -
Adcock and Shipley Parts
By bitza500 in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 27th Aug 2010, 01:03 PM -
A pommie mill adcock & shipley
By bitza500 in forum THE HERCUS AREAReplies: 0Last Post: 7th May 2009, 05:24 PM
