Results 1 to 12 of 12
Thread: HSS Machining
27th Oct 2016, 02:05 PM #1
HSS Machining
I need to turn the shank of a 22 mm HHS Slot Drill down to 20mm to fit my ER32 20 mm Collet, can this be done successfully with a Carbide cutting tip in the lathe.
Shane
Got the square peg in the round hole, now can't get it out !!
27th Oct 2016, 02:53 PM #2Most Valued Member
Wow that's a "how long is a piece of string"
It would depend on the lathe, the insert and the slot drill.
I wouldn't expect the shank to the hardened(well at least not as hard as the teeth). The two I checked arent. Grab a fine and try it.
Though you can get 22mm ER32 collets I believe.
Edit, couldn't find one on ebay but
ER32 Collet (individual) DIN6499B - COLLET
27th Oct 2016, 03:05 PM #3Most Valued Member
- Jul 2016
- 35
- 1,522
This is a pretty open question but if everything goes according to the Mohs scale you should be fine, depending on what kind of power your lathe has and how much you care about your carbide. End mills are probably hardened all the way through so i dont think you will get any relief every cut will be hard work. How are you planning on holding the endmill?
27th Oct 2016, 03:15 PM #4Most Valued Member
You can turn the end of at least one 20mm slotdrill with HSS*. It "files" the same until well into the start of the flutes.
*cheap slot drill, cheap HSS. I dont have an "good" straight shank slot drills. All my good stuff is charkson, so threaded end, which I would expect to be soft.
27th Oct 2016, 03:31 PM #5Senior Member
- May 2015
- Richmond
- 214
27th Oct 2016, 06:50 PM #6Pink 10EE owner
- 6,218
The bigger ones I have used the shank is friction welded onto the cutting region. Much like a taper shank drill.
I have turned down larger chinese end mills to fit them in a drill chuck.Gold, the colour of choice for the discerning person.
28th Oct 2016, 07:31 AM #7
Hi Shane,
My biggest ER32 collet is 22mm. So my preference would be to buy one rather than attempt to turn down the slot drill shank.Best Regards:
28th Oct 2016, 07:38 AM #8
Have only been able to find 22 mm slot drills with 25 mm shafts.
Shane
28th Oct 2016, 08:08 AM #9Most Valued Member
- 4,890
Are you going to try and cut an accurate slot with it or is it just for metal removal.
You can get them with 20 mm shank for under $32.00.
28th Oct 2016, 08:16 AM #10
Reasonably accurate if possible, I am going to use it more for squaring up some drilled holes.
Shane
28th Oct 2016, 08:19 AM #11Most Valued Member
- 4,890
Wouldn't that be better suited to a reamer?
28th Oct 2016, 09:10 AM #12
The holes that were drilled were not quite square to start with.
Shane
SOLD: Machining book"tabletop machining"
By woodsurfer in forum METALWORK - Machinery, Equipment, MARKETReplies: 4Last Post: 7th Feb 2012, 06:52 PM -
Machining key steel
By Phil Hansen in forum METALWORK GENERALReplies: 6Last Post: 2nd Jan 2010, 12:01 AM -
Machining Videos
By Big Shed in forum METALWORK GENERALReplies: 3Last Post: 25th Dec 2008, 10:06 PM -
Machining oil
By Bodgy in forum METALWORK GENERALReplies: 3Last Post: 23rd Apr 2008, 10:57 PM -
Machining copper?
By neksmerj in forum METALWORK GENERALReplies: 5Last Post: 5th Nov 2007, 10:31 AM
