Results 1 to 15 of 25
Thread: What the hell is it?
24th Oct 2016, 08:19 PM #1Golden Member
- Jun 2004
- Kyabram. Vic
- 632
Quite some time ago I purchased 2 Hardinge split bed lathes which came with 3 large plastic tubs of treasures of Hardinge and other bits & pieces. I started sorting through it yesterday. Quite a few end mills, a couple of horizontal mill cutters and slotting cutters, reamers, morse taper adapters, high speed steel, thread chasers etc as well as "what the hell are they items?"
Todays item is something that I probably always needed, maybe; if I know what it is. Looks brand new; Swiss made which should spark your interest B.T. I am leaning towards watchmaking; as there was also some minute turning tools as well as some letter stamps which look similiar to the markings on older proper watches and clock workings.
Ken
24th Oct 2016, 08:33 PM #2Diamond Member
- Mar 2014
- South of Adelaide
- 1,225
I think it might be a o ring measuring tool or something similar. you put the Oring over the shaft (i'm assuming the 4 shafts are tapered) and whatever making it lines up with is the size. that's my best guess.
24th Oct 2016, 08:40 PM #3Senior Member
- Jul 2012
- Griffith NSW
- 435
Looks like a hole guage, in thou perhaps?
24th Oct 2016, 09:44 PM #4Most Valued Member
Yeah hole/bore gauge is my guess. Take the pin out, put it in the hole, mark, put it back in the holder, read off the size????
24th Oct 2016, 10:28 PM #5.
- 6,458
Hello Ken,
It's a Zeigerlochlehre !! A watch and clockmaker's hand gauge for holes. There is a newer version illustrated in Bergeon's Essentiel13 catalogue.
BT
DSC_6882 (Large).jpg DSC_6885 (Large).jpgLast edited by Anorak Bob; 25th Oct 2016 at 07:26 PM. Reason: photos added for Variant.
25th Oct 2016, 01:35 AM #6
what are the words stamped or engraved on the tool?
regards from Canmore
ian
25th Oct 2016, 07:25 AM #7Golden Member
- Jun 2004
- Kyabram. Vic
- 632
Thanks BT. My guess was correct then. I have a vague recollection of "Lauris" being a top shelf watch/clock in days of old.
Ha.... Ian. You wish. They are so small that I can barely see them and I don't think I have anything with enough magnification to read them. I have used them and they leave a stamped imprint in a box. I will use them on a piece of alloy later in the day when these damn medicos have finished having their way with me. I will try a stamp loupe to see if I can decipher them. I don,t think that my macro lens will cut it; and I don't have anything like a microscope type lens.
Ken
25th Oct 2016, 01:26 PM #8Golden Member
- Jun 2004
- Kyabram. Vic
- 632
I am now sure that the punches are jewelers tools. I have been able to read the stampings and they are from the left ROCKENSHIRY, SILVER, 18CT, 9CT and 18CT with first 18 and 9 T being underlined.
These are the lathe tools, 1st is a D bit, 2nd appears to be an internal threading tool, 3 & 4 seem to be boring tools 5th is a tiny tapered D bit and the last is a match.
Ken
26th Oct 2016, 11:37 AM #9
Ken,
I just sent a PM with my details.
I'd love to have a chat about those punches.
Peter
.....Who has his own set of that kind of punches!!!
Peter McBride Goldsmith Jeweller
26th Oct 2016, 01:28 PM #10Golden Member
- Jun 2004
- Kyabram. Vic
- 632
PM received Peter.
After further research in the right direction they original gauge turns out to be a "Watch hand hole gauge". Its use is to measure the size of the holes in watch hands. The hole at the base of the hand is placed over the tapered pin; and the scale then gives the hole size.
I have found some more bits & pieces; square emery stick (well used) for deburring, 2 tiny vices, quantity of piercing saw blades and a brass handled item with a hardened tapered point which I originally thought was a scribe. On magnifying the point I found 2 tiny grooves and I now think that it may be a hole deburring tool.
The item in first photo I think is is the support for an intermediate step pulley for a tiny round belt watchmakers lathe.
The second item appears to be for holding work between centres and balancing gears/wheels etc.
Ken
26th Oct 2016, 04:59 PM #11
Hi Ken,
I have about 20 punches of jewellers working in the late 1800s to early 1900s.
Your Punch marks are very, very interesting to me.
I've done some searching after looking closely at the mark you made.
There is a first letter, partly punched in one of your marks.
It has taken most of the morning BUT !!!!
What you have are the punches of Messrs Brockenshire,
They were working in Collinigwood & North Fitzroy at exactly my period of interest.
Look here.
16 May 1896 Weekley Times Melb Advert.
and here a story about a jewellery thief being sentenced....
04 Jul 1901 - JEWELLERY THIEF SENTENCED. - Trove
It was a treat to have a long chat
Peter
26th Oct 2016, 05:05 PM #12
Ken,
Here are the some of the punch marks I told you about.
Those of W Slomell, the pipe maker, silversmith and ivory & shell worker from Royal Arcade Melb.
His other tools are here
Peter
26th Oct 2016, 05:13 PM #13.
- 6,458
The hand hole thing prompted another look through my collection....You are spot on Ken. Any chance of a photo or two of the vices?
26th Oct 2016, 05:25 PM #14.
- 6,458
Hey Ken,
A bunch of manufacturers made similar stands as spindle mounts - two pages from Millers Falls' 1938 cataogue
BT
26th Oct 2016, 07:14 PM #15Golden Member
- Jun 2004
- Kyabram. Vic
- 632
Hello Bob,
Peter has also came up with your findings of the spindle mount. He also thinks that item number 2 is a metal lathe; or even machining ivory. He believes it may be a watch makers "bow lathe". Similiar concept to a woodworkers pole lathe. Imagine bow used in 1 hand and graver applied with the other.
Ken
Hell !
By BaronJ in forum METALWORK GENERALReplies: 1Last Post: 25th Jan 2016, 06:56 AM -
One of those "What the hell?" moments
By Michael G in forum METALWORK GENERALReplies: 13Last Post: 19th Oct 2012, 10:13 AM -
Tips/Tricks on avoiding the "Bloody hell its hot and down my shirt" dance
By takai in forum METALWORK GENERALReplies: 11Last Post: 6th Feb 2010, 03:43 AM -
how the hell do i send pictures
By patty in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 10Last Post: 9th Jan 2008, 11:52 AM
