Results 1 to 6 of 6
Thread: weld positioner
14th Oct 2016, 01:27 PM #1Senior Member
- Apr 2013
- Bunbury WA
- 98
weld positioner
https://m.youtube.com/watch?v=20b8EyIDIMY
This is a video of a weldpositioner I made using the sprockets from old bicycles. I used this link after giving up waiting for the video to download off my ipad. If I were to make it again I would probably have the second idler on the drive shaft, I might change that yet, but will use it as is for now
14th Oct 2016, 04:12 PM #2Senior Member
- Dec 2007
- 103
Looks pretty cool. In the video you mentioned a PWM speed controller for the wiper motor - do you have any details? I have been thinking about a wiper motor to drive my bead roller and speed control would be useful.
Grant
14th Oct 2016, 04:18 PM #3Senior Member
- Jan 2012
- Hinchinbrook
- 112
Neat! What sort of welding do you regularly do on that?
Just a thought. Would it not have been easier to just isolate the faceplate from the rest of the drive? Although as the work potential should be relatively zero I'm not so sure that the welder voltage would interfere or affect the drive motor anyway. I guess if you strike an arc and the motor accelerates to 1500 RPM you might notice that
Cheers Phil
14th Oct 2016, 06:48 PM #4Senior Member
- Apr 2013
- Bunbury WA
- 98
Phil, I was welding once on a conveyor frame and it earthed back through the motor and cooked it so I have found out the hard way that you can burn out a motor with a welder.
Grant, if you look for a pwm ( pulse width modulator) controller on ebay you'll find plenty. Mine came from China and I put it in an old guitar footpedal box I made years sgo. It cost very little. The beauty of a pwm is it doesn't loose much torque. Normally this drives the table on my mill.
14th Oct 2016, 07:09 PM #5Senior Member
- Dec 2007
- 103
14th Oct 2016, 09:36 PM #6Senior Member
- Apr 2013
- Bunbury WA
- 98
Grant I haven't a clue, I used a 12 volt power pack from a computer, it has never struggled on the mill and I cant see it being any different with something slung between centres either.
Weld Positioner
By ImJay in forum METALWORK PROJECTSReplies: 2Last Post: 25th Aug 2016, 10:09 PM -
Weld Art?
By newbyangler in forum WELDINGReplies: 20Last Post: 5th Jun 2016, 09:01 AM -
Can you over weld ali?
By constablechris in forum WELDINGReplies: 18Last Post: 5th Feb 2012, 06:34 PM -
Rate my weld please!! :)
By dickies_ in forum WELDINGReplies: 5Last Post: 27th Jun 2009, 06:24 PM -
Weld positioner fixture or carvers vice
By Grahame Collins in forum WELDINGReplies: 13Last Post: 20th Oct 2007, 10:09 AM
