Results 1 to 15 of 16
Thread: Phosphor Bronze
19th Aug 2016, 09:36 AM #1
Phosphor Bronze
Is there a substitute to use for Phosphor bronze as a washer.
Shane
Got the square peg in the round hole, now can't get it out !!
19th Aug 2016, 09:42 AM #2Member: Blue and white apron brigade
Depends on the intended use.
19th Aug 2016, 11:12 AM #3
It is the outside washer on a moving rod, doesn't have any pressure on it, it is just a retaining washer.
Shane
19th Aug 2016, 01:32 PM #4Member: Blue and white apron brigade
19th Aug 2016, 01:59 PM #5
reciprocating like a conrod, would estimate max rpm would be 200 rpm
Shane
19th Aug 2016, 05:27 PM #6Senior Member
- Jun 2016
- 283
I am not sure you could not use steel for that. Low revs, low pressure - why not?
Roger
19th Aug 2016, 05:42 PM #7
19th Aug 2016, 06:25 PM #8Senior Member
- Jun 2016
- 283
NOT stainless steel. It is too soft and prone to galling.
Case hardened MS would however be fine. Quite possibly ordinary polished MS might also do fine. To be honest, I would bung an ordinary steel washer in and see how it goes.
Roger
19th Aug 2016, 08:07 PM #9Philomath in training
- 6,562
What size washer is it? I have some left over Phos bronze here (38mm diameter I think) so could make something up if it was not too big.
20th Aug 2016, 07:10 AM #10Shane
20th Aug 2016, 08:35 AM #11Senior Member
- Jun 2016
- 283
Clearly, we need photos of the Steam Train.
Roger
20th Aug 2016, 08:47 AM #12
Only have the frames, wheels and axles done at the moment, will look into getting a few pictures.
and this is how the completed train looks.
forum 2.jpgforum 3.pngShane
20th Aug 2016, 09:07 AM #13Senior Member
- Jun 2016
- 283
Just out of curiosity, where does the washer go?
Roger
20th Aug 2016, 09:16 AM #14
This is one of the original construction photo's and it goes at the tip of the red arrow.
100_2743 - Copy.jpgShane
20th Aug 2016, 10:24 AM #15Senior Member
- Jun 2016
- 283
oookkaayy
A good steel disk would be fine there. However, have you thought of using UHMWPE instead? Something like Polystone 1000 (green). It is used to line huge mining dump trucks. The steel buckets used to wear out in 12 months; the Polystone liners last for years. Hard to imagine, but it works. Lacking high pressures, such a washer would last 'for ever' there.
Roger
Bronze Bushes
By BobL in forum METALWORK GENERALReplies: 5Last Post: 25th Nov 2015, 08:52 PM -
TIG vs Nickel Bronze
By Gavin Newman in forum WELDINGReplies: 12Last Post: 3rd Nov 2015, 02:41 PM -
phosphor copper -Where do you get it
By rusel in forum METALWORK GENERALReplies: 7Last Post: 23rd Mar 2012, 11:00 PM -
Bronze bush. What type of bronze?
By simonl in forum METALWORK GENERALReplies: 23Last Post: 5th Oct 2011, 09:40 PM -
Bearing bronze
By Tiger in forum METALWORK GENERALReplies: 7Last Post: 31st May 2008, 05:52 PM
