Results 1 to 2 of 2
Thread: Y Axis Way Cover
20th Jul 2016, 10:18 PM #1
Y Axis Way Cover
Some time back, BaronJ was kind enough to send me a piece of silicon sheet so I can make a new way cover for my mill Y axis. I told him I would post about it on the forum. Well I finally got around to finishing it off today.
A before shot. When I fitted the DRO, I had to lift the bottom edge of the Z axis cover upwards to provide clearance for the x axis DRO scale. I also made a new mounting plate as the original one was daggy. Raising the cover allowed chips to fall down the reccess on each side of the column so I fitted this temporary shield.
The new cover attached to the back of the table. The arrow points to a slit I cut in the cover to clear the Y axis DRO scale, chip cover edge.
The cover mounted in the same bolt holes as the z axis cover. I made the cover longer to reach these bolt holes.
All the messing around caused this. The strip that grips the ways has come unstuck. I was surprised it has held up so well. The DRO install knocked it around a lot as well. I pulled it off and stuck it up with some contact adhesive.
Back together. The red arrow indicates where the column base pinches the cover when the table is moved to the rear. The blue arrow indicates the position where the Y axis DRO scale cover edge is located. This pinches the cover against the column base. I need to fit some sort of spring loaded lifting device to hold the cover up.
The table nearly at the back position. That loop of silicon is pushed down by the scale cover jamming it against the column. The lifting device will fix this too. Other than those problems it works well.
24th Jul 2016, 01:33 AM #2
Way cover
Hi Dean,
Nice ! I'm glad that you have got it sorted. Mine did the same as yours with the folding up when the table was wound right back, though on my machine the DRO scale is on the front so no real issues there.
My main problem was just how close the fixing holes on the rear of the table were to the dovetails.
I now need to replace the silicone baking sheet on the lathe since I ripped a hole in it trying to turn a piece of plastic plate that was really to big on the face plate. I only had about 5 mm clearance to the bottom of the gap. Of course as soon as I wound the saddle forwards the silicone sheet folded and the work piece grabbed it.
PS. Sorry about the slow reply. No:2 Granddaughter needed looking after whilst parents were away.Best Regards:
Car cover as a shed?
By neksmerj in forum METALWORK GENERALReplies: 7Last Post: 27th Aug 2014, 12:53 PM -
machine cover
By eskimo in forum METALWORK GENERALReplies: 0Last Post: 13th Aug 2013, 11:04 AM -
Ways cover
By Tiger in forum METALWORK GENERALReplies: 7Last Post: 14th Oct 2009, 01:00 AM -
Cover lens spares for Tecmen AD helmet
By Grahame Collins in forum WELDINGReplies: 1Last Post: 1st Sep 2007, 06:30 PM
