Results 1 to 15 of 17
9th Jun 2016, 11:22 PM #1Senior Member
- Sep 2007
- Melbourne, Australia
- 149
Where to get an Old Propane or Air tank
Hey guys,
I've recently built a double barrell smoker for my uncle - he loves it, ribs cook up fantastic.
I currently have a timber smokehouse but I want to replace it with a offset smoker. Problem is, I cant find an old air compressor tank (large) or an old propane tank anywhere.
have been scouring gumtree and ebay, the scrap metal salvage yard down here is a nightmare to search through, so any ideas?
This is what im lookign for something like a 60gallon drum, or there abouts.
9th Jun 2016, 11:52 PM #2Most Valued Member
Hi,
Try the places that convert cars to gas, they also check for out of date ones. Failing that motor wrecking yards, would be another choice.
10th Jun 2016, 10:11 AM #3
Hi,
Do you seek 60 liters (13 odd gallons) or 60 gallons capacity? The pic shows possibly a 60 litre cylinder if it is on a standard pallet.
60 gallons converts to 272 litres. That won't fit well in the boot of a car.
If the 60 gallon size is correct, I would assume you are smoking something very large. A camel perhaps?
I googled and found this
60L UN Embossed Stainless Steel Drums | Stainless steel drums that can be re-used.
They mention POA which may be a bit scary?
10th Jun 2016, 10:26 AM #4New Member
- Mar 2014
- Craigieburn
- 8
Hi,
Try your local truck wreckers. Trailers have 2 or 3 air tanks of different sizes up to 72 litre to operate brakes, air bags, etc.
Nifty.
10th Jun 2016, 11:04 AM #5Senior Member
- Dec 2009
- 327
There are companies that wash out LPG cylinders (to a standard) so they can be scrapped safely. Talk to LPG mechanics, gas fitters and suppliers about where the old ones go to, probably happy to be rid of them.
regs,
A.'Waratah' spring hammer by Hands & Scott c.1911- 20, 'Duffy, Todd & Williams' spring hammer c.1920, Premo lathe- 1953, Premo filing machine.
10th Jun 2016, 12:01 PM #6Member
- Dec 2010
- Mornington Peninsula
- 97
As advised previously, look at car/truck wreckers.
I got mine from a 4x4 wrecker at Somerville.
10th Jun 2016, 01:07 PM #7Most Valued Member
- 4,258
I turfed a 150 litre SS water heater last week...the cold water Bypas pipe was stuffed
10th Jun 2016, 03:18 PM #8Senior Member
- Dec 2015
- 202
Railway workshops or places that scrap trains. Like trucks, every bit of rolling stock will have a large air tank for the tripple valve and brake gear to operate. You can't get the brakes to come off if you don't have enough pressure to put them on again!!
10th Jun 2016, 05:09 PM #9Golden Member
- Mar 2009
- 54
- 825
G'day Oohsam,
I've got a steel 70lt car LPG tank at home, it's yours if you want it.
It still has a bit of liquid/gas in it but it shouldn't be problem to decant or get rid of it.
PM me if you want it.
Greg.
11th Jun 2016, 08:16 AM #10Senior Member
- Sep 2008
- texas, queensland
- 248
might be easier quicker and safer to get a flat sheet rolled and mig weld it and make your own end , they dont have to be domed for a smoker . or a steel place that sells large diameter pipe .
johno'If the enemy is in range, so are you.'
11th Jun 2016, 09:32 AM #11
A thing that has just occurred to me is the effects of mercaptan which is the smelly additive that gives LPG its distinctive smell.
It is very hard to remove as the smell lingers.
Question is,could there be any any effects from food smoked in a cylinder that has held this stuff?
11th Jun 2016, 10:09 AM #12Member: Blue and white apron brigade
I subjected the propane tank I used for my gas forge with 7 washings with hot water and detergent but I could still still smell mercaptan in the air when I flushed it with compressed air line. Then when I cut the tank with an angle grinder it let off a small pants staining woof and the was almost certainly due to the mercaptan coming out of the rust along the line of the cut. I could not smell anything after that probably because it was able to dissipate freely (i.e. could not continue to come out of the remaining rust and accumulate) .
Anyway it's highly flammable and would imagine the first firing of the smoker would burn any remaining residue.
11th Jun 2016, 07:30 PM #13Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
I would first try an auto wrecking yard, if I recall correctly, they have to pay to have LPG tanks disposed of properly, and it's a real problem when a full one goes through the crusher, so they should be more than happy to be rid of them.
11th Jun 2016, 09:37 PM #14Senior Member
- Apr 2008
- 269
Bloke
Try getting an old stainless steel solar hot water system. I have converted a few of those into painted cray cook pots for fellas in the Pilbara when I lived up that way, cut the ends off, welded on 3 legs, job done. Drive around and have a look on roofs in ya neighbourhood, solar hot water system with black ends are steel, ones with stainless ends are SS. Check out some of the solar hot water systems suppliers in your town, I got mine from the local rubbish tip.
DD
12th Jun 2016, 03:25 PM #15Golden Member
- Feb 2010
- Ballina, NSW
- 900
Yes, LPG car conversion places will definitely have some. I have a couple of stainless tanks that apparently where beyond some test date or another for free. I cut one in half with the intention of making a big crab cooker. The was no trace of mercaptan smell, but what I didn't realise was how the domes were welded in on each end. The inside isn't finished flush as the dome is rolled in further than need be, and the outside cylindrical panel is welded to the outside (i.e. not a butt join). So for my application, it wasn't ideal. The metal was about 3, maybe 4mm thick from memory.
What is a bypass smoker anyway? and what function does the tank have? Smoke cooling? I tried to google it but just got lots of links to open heart surgery.
[edit: just read dingo's post - same idea but his is better implementation by the sound of it!]
- Mick
New tank for plasma
By clive hugh in forum METALWORK GENERALReplies: 1Last Post: 4th Jan 2016, 04:41 AM -
Etchant Tank.
By DSEL74 in forum METALWORK GENERALReplies: 13Last Post: 5th Dec 2015, 11:09 PM -
Petrol tank
By gooddroprob in forum METALWORK GENERALReplies: 19Last Post: 3rd Oct 2014, 09:23 AM -
Propane Burner Pilot Size
By electrosteam in forum METALWORK GENERALReplies: 5Last Post: 14th Aug 2014, 10:12 PM -
adaptor US propane torch?
By Mindabout in forum WELDINGReplies: 11Last Post: 12th Dec 2009, 09:50 PM
