Results 1 to 11 of 11
Thread: L-00 spindle spanner
3rd Jun 2016, 07:09 PM #1
Question for those with the old U.S. standard L-00 , L-0 and larger spindle nuts .
What do you use to undo the nut ? A C spanner or hook spanner is needed but a large sized one is not easy to find. A guy in the US makes these spanners but the freight is a killer, US $70+ . He cuts them out of high tensile 1/2" plate .
3rd Jun 2016, 07:28 PM #2Philomath in training
What size diameter are you talking Mike? I use an adjustable (originally sold for doing motorcycle shocks) on my ER40 collet nut, so there may be other non-obvious sources out there.
3rd Jun 2016, 07:57 PM #3
Hi
Yes I spotted the motorbike shock spanners but they are not big enough.
I measured the centre of the L-00 spindle nut and it is 4.5" diameter . There is a plain section in the middle of the nut perimeter where the spanner locates and some knurling on either side of the plain bit . There are six notches around the circumference of the nut, for the spanner to locate.
Regards Mike
3rd Jun 2016, 07:58 PM #4Most Valued Member
- Australia east coast
- 2,713
Lots bigger than that...
Lathe Spindle Fittings Page 2
I'd just make a spanner myself, it'd be quicker than asking about something so simple.
There's a very nice P-B collet chuck with a L-00 spindle mount I keep here as a reminder to not be so enthusiastic in buying stuff that won't fit any of my lathes. The damn thing is way too hard for me to want to machine it. I keep thinking of making an adaptor up but I can buy a D1-6 mount chuck at a reasonable price so there's no incentive. Makes a lovely door stop anyway.
PDW
3rd Jun 2016, 08:09 PM #5Philomath in training
I guessed it would be but how big was the important question. Our workshop have cut C spanners of around that size from flat plate. Another option is perhaps hydraulic equipment servicing places as that is a size sometimes used on injection moulding machines and earthmoving equipment.
I agree with Peter though and would just look at making one. I can see them in the US for between US$42 (adjustable) up to around US$75 for a fixed one and freight would probably be another US$30 to US$40 - that's a lot of plate.
3rd Jun 2016, 08:12 PM #6
3rd Jun 2016, 09:11 PM #7Golden Member
- Mar 2009
- 54
- 825
G'day Mike,
I reckon you could knock one up from some 1" x 0.25" flat black iron.
Cut a section to the required dimensions for the key, drill and tap it with an appropriate thread and bolt to the end of a longer piece (or just welding it on might be easier and stronger)
Bend to the required shape and weld on a brace.Maybe add a half twist to the handle under the brace to reduce the chances of the handle bending beyond the brace.
Cut to length and add preferred handle.
Sort of like this (I couldn't draw the twist):
Greg.
8th Jun 2016, 09:33 AM #8.
- 6,459
Hello Mike,
The wonderful Schaublin No.36 vice Michael procured for me required a largish C spanner for locking the rotatable jaws. I looked high and low and eventually found a spanner here - C Spanner Hook Wrench w Pin Slotted Roller Bearing Nut Option 58 115mm | eBay Good quality and what I would call a pretty reasonable price.
Might do for your chuck.
Bob.
8th Jun 2016, 01:24 PM #9
Many thanks... I just bought one !
10th Jun 2016, 07:31 PM #10
C tool
The C Tool arrived OK.
Lucky for me the large nut on the L-00 spindle has come undone easily . The tapered surface on the spindle itself is OK, it has some light pitting marks but it is smooth and serviceable . The chuck is not so good, the L-00 taper surface on the back plate is rusty and has some dings in it . The other chuck isn't much better . I might have to look into buying some L-00 back plates . I would hate to damage the spindle taper, using damaged back plates on it isn't a good idea..
11th Jun 2016, 01:49 AM #11
For future reference and for others: an eBay search like this
adjustable C-spanner | eBay
brings up lots of adjustable hook and pin spanners. I've bought a few for the various nuts I Have on machines and motorbikes. Even though some look to be of dubious quality, I've not bent or broken any - yet.Cheers, Joe
Spanner sizes
By DSEL74 in forum METALWORK GENERALReplies: 45Last Post: 31st May 2018, 12:26 AM -
NT 30 spindle spanner
By Dave J in forum METALWORK GENERALReplies: 26Last Post: 27th Sep 2012, 06:22 PM -
Mitutoyo micrometer spanner
By iron bark in forum METALWORK GENERALReplies: 5Last Post: 10th Sep 2012, 02:57 PM -
Overkill on a Pin Spanner
By Abratool in forum METALWORK GENERALReplies: 44Last Post: 1st May 2012, 02:21 PM -
Spline Spanner
By Sterob in forum METALWORK GENERALReplies: 7Last Post: 18th Sep 2007, 08:01 PM
