Results 1 to 15 of 16
Thread: New machinery purchase
21st Apr 2016, 09:55 PM #1Member
- Feb 2012
- 61
Hey guys, I bought a brobo. It's a s350d brobo Waldown cold saw. It needs a lot of work but I got it for a steal.
I have ordered a new pivot block from brobo. And I am starting teardown this weekend, should be a fun project.
21st Apr 2016, 10:01 PM #2Most Valued Member
That'll come in nice and handy once it's finished. Are you going to do a WIP?
21st Apr 2016, 10:24 PM #3Member
- Feb 2012
- 61
I will try to keep it updated
29th Apr 2016, 07:21 PM #4Member
- Feb 2012
- 61
I've started the clean up process, I've got the bevel plate free and re-greased.
I have also received the pivot block from Brobo and fit it to the saw.
29th Apr 2016, 07:23 PM #5Member
- Feb 2012
- 61
Also, anyone able to weld aluminium in the Campbelltown area? I want to remake the coolant tray. I will cut all the parts from some scrap aluminium diamond plate. I just need someone to weld it up for me.
19th May 2016, 09:32 PM #6Member
- Feb 2012
- 61
Making progress, waiting on some partsvfrom brobo, including a new single phase motor.
Sent from my SM-P555 using Tapatalk
19th May 2016, 11:29 PM #7Philomath in training
Might pay to check the function of the diaphragm coolant pump - from memory they are one of those essential things that can fail over time.
20th May 2016, 08:57 AM #8Senior Member
- Jul 2012
- Griffith NSW
- 435
The pumps do get awfully gungy too, which stops the valves inside it from sealing well. Its not a complicated component, just filthy work.
If you need any measurements or photos of bits and pieces for that machine, sing out - we've got that exact saw at work.
23rd May 2016, 12:16 PM #9
I have an earlier version where the coolant pump runs of a cam on the rear of the motor.
The pump is off a Viva or Gemini. Yours looks similar.
So we got the diaphragm from Repco no probs.
H.Jimcracks for the rich and/or wealthy. (aka GKB '88)
3rd Jun 2016, 07:33 PM #10Member
- Feb 2012
- 61
Its Alive! I have wired up the saw (after this photo was taken), with the new switch and new motor.
Now i just need to clean the vise and check out the coolant pump.
My blade should be here in a week or 2 from hare and forbes. It has been a fun project so far.
3rd Jun 2016, 10:02 PM #11Senior Member
- Jan 2015
- 211
10th Jun 2020, 11:14 PM #12New Member
- Jun 2020
- Bungarribee
- 1
What was your plan of attack in getting the Rotary Table back in working order?
I've noticed that these older models are fairly inaccessible when it comes to cleaning under the rotary/bevel table.
I am fairly reluctant to completely remove the gear box assembly from the pivot block at the back, but figure that this is probably that only way to get my S053D Brobo greased sufficiently. It really doesn't want to budge. My guess is that it was used in the 90 degree cutting position for 30+ years! Wish me luck...and feel free to shoot me any hot tips.
13th Jun 2020, 10:56 PM #13
Hi Steve,
Welcome to the Metalwork Forums.
To help explore the areas of our forum here's a guide on to to navigate our Forum and find all the goodies.
Goto the FORUM box in the top left hand cnr of the page and click the down arrow. This will bring up a pull down menu that has Forum Home at the top
Click Forum Home which will present a scroll down page.
Our rules,the Terms of Service are right at the top ,we encourage you to read them.
Below that are all the various areas and sub forums that make up out MetalWork forums.
If you want to post pics in your first ten posts sometimes our moderation kicks in I may have to moderate them manually.
Welcome
14th Jun 2020, 02:40 PM #14Senior Member
- May 2013
- Rockhampton, QLD
- 68
- 455
Welcome to the forum Steve.
Ross
16th Jun 2020, 01:26 PM #15Senior Member
- Jul 2014
- melbourne
- 110
many years ago at work a fitter was moving a brobo saw with a forklift and tipped it over and snapped the pivot casting in half, he repaired it by welding it up, did a good job too, same fitter also broke a blade in a large guillotine that was jammed with the blade down, he levered on a 6ft crowbar and chipped a large chunk out of the blade, boss was not happy
Oxy Cyinders - Purchase
By eskimo in forum METALWORK GENERALReplies: 55Last Post: 8th Oct 2015, 05:49 PM -
Which Tap & Die set to purchase?
By FenceFurniture in forum METALWORK GENERALReplies: 80Last Post: 2nd Feb 2014, 07:36 PM -
New purchase
By nearnexus in forum METALWORK GENERALReplies: 20Last Post: 29th Jul 2013, 05:06 PM -
SOLD: 1930's 1940's and 1950's English Mechanic's, Machinery Lloyd and Machinery Magazine
By onetwoone in forum METALWORK - Machinery, Equipment, MARKETReplies: 13Last Post: 21st Jan 2013, 07:16 PM -
Welding, Purchase
By Greg40 in forum WELDINGReplies: 5Last Post: 9th Jan 2010, 11:57 AM
