Results 1 to 2 of 2
Thread: Keyway Broaches
    May 2006
    Canley Heights, NSW
    67
    529
    Default Keyway Broaches
    Can someone explain the difference between A,B & C style Keyway Broaches.
    Cheers Shane.
    Shane
    Got the square peg in the round hole, now can't get it out !!
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,559
    Refers to the size of the slot that the broach slides in while working, which in turn relates to the size of the bush in the hole being broached - so (as an example with randomly selected numbers) you might have a 5mm B broach that will fit bushes from say 12mm to 19mm diameter, where a 5mm C broach will do 18mm up to 26mm.
    You can of course make up your own bushes for what ever size hole you wish to broach.
  1. Internal Keyway
    By Auskart in forum METALWORK GENERAL
    Last Post: 15th Apr 2016, 09:39 AM
  2. Keyway broach 3/16
    By Greolt in forum METALWORK GENERAL
    Last Post: 30th Mar 2016, 09:38 PM
  3. Keyway in shaft
    By Chrism3 in forum METALWORK GENERAL
    Last Post: 25th Aug 2015, 06:47 PM
  4. Keyway in a tapered bore
    By bob ward in forum METALWORK GENERAL
    Last Post: 13th Sep 2013, 11:06 PM
  5. Keyway bar
    By 46150 in forum METALWORK GENERAL
    Last Post: 23rd Jan 2010, 11:51 AM
