Results 1 to 13 of 13
10th Apr 2016, 04:53 PM #1Member
- May 2012
- melbourne
- 60
4 facet sharpening problems, ER40 collet block doesn't hold the drill concentric
I've been messing about with 4 facet sharpening, using a 3-way vice and a 4 sided ER40 collet block to hold the drill in a T&C grinder
Most frustrating trying to get the facets to cross nicely and the drill to drill on size - the resulting hole is about 22.24 (worst case) for a nominal 22 mm drill (actual measurement about 21.95)
It looks like the collet block won't hold the drill concentric, seems to be that the collet only covers about 80% of a full turn of the flutes
Anyone used ER collets to hold relatively large drills with any success or otherwise ?
Maybe I'll need to make a long v-block with a registration finger and length stop to mount in the vice
10th Apr 2016, 05:58 PM #2Member
- May 2012
- melbourne
- 60
Success... 16mm drill is fine, looks like an er40 collet is only good for 19mm of so sized drill
I tried with a 16mm drill, it's held concentric, pretty much. Facets turned out fine, resulting hole is about .04 mm oversize - good enough for me
10th Apr 2016, 07:20 PM #3Most Valued Member
- Jun 2012
- SA
- 1,649
The worst that can happen is you will fail.
But at least you tried.
10th Apr 2016, 08:33 PM #4
Hi John,
Apart from the problem that I found with my ER16 collet chuck, I think that for a drill of that size, nicks or burrs on the drill edges would cause the type of run out that you describe. Equally there could be a burr on the inside of the collet. I've recently purchased an ER32 / MT3 collect chuck for my mill and discovered that a couple of the collets have rough edges on the slits at one end which makes it hard to push a cutter in. I've used a diamond file to take the edges off and 800 grit emery paper in the slits. Not easy on a 1/2" collet !Best Regards:
10th Apr 2016, 08:47 PM #5Member
- May 2005
- Cockatoo Vic
- 84
I think you will find it is not that the collet is crap.
More likely a result of gripping the drill close to the business end.
That means it is only gripping a relatively small section of the spiral cutting edge. Probably not a full 360 degrees of cutting edge.
A lot different to gripping a solid 22mm bar as the ER collet was designed to do.
Absurd is a strong word to use without thinking about what the OP is trying to use the collet for.
10th Apr 2016, 09:13 PM #6Most Valued Member
- Jun 2012
- SA
- 1,649
Where does the OP say that ?
If the OP is trying to grip on the flute section of the drill (LOL) that's something no ER collet was designed to do.
ER collets can grip all or part of their length.
I've used ER collets for many years and know what they can and should be able to do.
The OP made an absurd statement about ER40 collets - regarding larger sizes.
Rob.The worst that can happen is you will fail.
10th Apr 2016, 09:27 PM #7
10th Apr 2016, 09:29 PM #8Most Valued Member
- Jun 2012
- SA
- 1,649
Trying to grip on the flute section is madness.
10th Apr 2016, 10:05 PM #9
10th Apr 2016, 11:31 PM #10Member
- May 2012
- melbourne
- 60
I checked the collet / block with a piece of bright bar, it was true, or pretty close
Then I did the same with the drill, maybe with the point protruding 30 mm or so, it was a bit out, not much, but seemingly enough to mess up the point
Did the same check with the 16 mm drill, it was concentric, and a good result with sharpening
I didn't attempt to mount the shank in the collet, I assumed the runout at the point would be unacceptable
If you look at the various drill sharpening jigs, the drill is held in a v-block or similar close to the pointy end (on the flutes. or maybe I should say lips, but who calls them that down the pub) - I don't recall a drill held for sharpening at the shank end
Anyway, I thought the the collet would average out over the lips, regardless of size, but it seems that the grip is unreliable if the collet doesn't cover a full spiral twist
Maybe it's a bit of a watchit for people building sharpeners using ER collets, perhap you can't hold drills to the full range of the collet capacity and have reliable concentricity. maybe the old-fashioned v-block and indexing finger is the go
11th Apr 2016, 01:09 AM #11
11th Apr 2016, 10:01 AM #12Most Valued Member
- Jun 2012
- SA
- 1,649
11th Apr 2016, 10:43 AM #13Member
- May 2012
- melbourne
- 60
I was emulating the GadgetBuilder setup (link below) but using a vice and collet block in the grinder
The geometry is easy enough to achieve, but accuracy and repeatability not so easy
I had the drill held similarly to that in the picture (business end held in collet, little bit of stickout, just for wheel clearance)
http://www.gadgetbuilder.com/4_Facet_Overview1.jpg
ER40 Collet Chuck for Lathe
By Oldneweng in forum METALWORK PROJECTSReplies: 12Last Post: 31st Jan 2016, 04:53 PM -
ER40 Collet nut dimensions
By scottyd in forum METALWORK GENERALReplies: 6Last Post: 9th Nov 2014, 12:20 PM -
ER40 collet chuck for 260???
By ventureoverland in forum THE HERCUS AREAReplies: 12Last Post: 27th Sep 2014, 11:21 AM -
D1-6 ER40 collet chuck
By Ueee in forum METALWORK GENERALReplies: 13Last Post: 7th Nov 2013, 11:26 PM -
Er40 Collet Chuck
By localele in forum THE HERCUS AREAReplies: 7Last Post: 21st Jan 2012, 08:47 PM
