Results 1 to 15 of 20
Thread: How To Remove Old Silastic, Etc.
26th Jan 2016, 11:29 AM #1
26th Jan 2016, 12:11 PM #2Member: Blue and white apron brigade
Concentrated acetic acid is solvent for silastic but don't bother trying regular vinegar as it doesn't seem to touch it.
It will also readily dissolve galv so it may not be appropriate for your door frame.
If you can get hold of conc acetic acid be careful with it as it is sticky like jam and you might think you have removed it from skin but the burns don't show up for some time afterwards.
Make sure you read the MSDS for it.
26th Jan 2016, 12:43 PM #3Member
- Jun 2010
- Wimmera
- 96
Eucalyptus oil and elbow grease. It will remove it.
Hooroo
John
26th Jan 2016, 02:48 PM #4Most Valued Member
26th Jan 2016, 02:52 PM #5Banned
- Feb 2015
- Oz
- 73
- 459
There is a commercially available silicon remover, I believe Bunnings stock it.
26th Jan 2016, 03:53 PM #6Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
Try also petrol.
26th Jan 2016, 06:46 PM #7
Petrol or kero will work on many types of silastic - but it can take a few hours/overnight for it to do its job.
26th Jan 2016, 07:00 PM #8Most Valued Member
- 4,890
What if you use a match?
26th Jan 2016, 08:35 PM #9Most Valued Member
26th Jan 2016, 11:25 PM #10Member
- Jul 2013
- BRISBANE BAYSIDE
- 90
I have had success using mineral turps to remove old silicone sealant on fibreglass and perspex, followed by a final clean with Shellite.
Alan
27th Jan 2016, 09:03 AM #11Diamond Member
- N.W.Tasmania
- 1,407
I presume that your suggestion is in jest, and you meant using the match after Master Splinters method of using petrol to soften the silastic. For the record, silastic will take quite high temperatures, much higher than a match alone could provide. The addition of petrol vapour however provides a whole range of additional possibilities.
27th Jan 2016, 11:12 AM #12Pink 10EE owner
- 6,218
cup wire brush on an angle grinder.
27th Jan 2016, 02:35 PM #13
27th Jan 2016, 03:29 PM #14
27th Jan 2016, 07:54 PM #15
The silicon remover is made by Selleys
How to remove rust protection
By woodfast in forum METALWORK GENERALReplies: 2Last Post: 21st Aug 2014, 11:30 PM -
How do you remove the apron from an ATM260
By dle147 in forum THE HERCUS AREAReplies: 3Last Post: 20th Sep 2011, 09:45 PM -
how to remove the chuck on a 260g
By welder in forum THE HERCUS AREAReplies: 4Last Post: 25th Jul 2011, 10:41 AM -
How do I remove old grease
By Bidgee in forum METALWORK GENERALReplies: 6Last Post: 14th Apr 2010, 10:00 AM
