Results 1 to 1 of 1
Thread: CVA mill motor mount
20th Jan 2016, 08:47 PM #1
This will interest Andre .
I discovered that a standard modern flange mount motor will fit snugly into the original CVA motor end casting .
I made up 4 angled supports and my neighbour brazed these onto the CVA casting . I can now bolt the new flange motor to the old CVA motor end casting. I need to turn up a shaft extension for the new motor .
I am using a 1hp motor , the ancient original motor is 3/4 hp 950 rpm . Mike
Cooling down a mini-mill motor
By Jors in forum METALWORK GENERALReplies: 5Last Post: 15th Jan 2013, 09:10 AM -
DONE: 355mm hot saw, 3 phase motor & VFD, Steel, HDPE, Alumi..... Pickup Mount Annan, 2567
By Ch4iS in forum METALWORK - Machinery, Equipment, MARKETReplies: 4Last Post: 12th Oct 2012, 09:18 PM -
Removing Mill Motor
By electrosteam in forum METALWORK GENERALReplies: 7Last Post: 10th Jul 2010, 09:54 AM -
Best Way to Mount a Mill and Lathe
By markjaffa in forum METALWORK GENERALReplies: 4Last Post: 14th Apr 2010, 11:23 AM -
tread mill motor
By BigStick in forum METALWORK GENERALReplies: 4Last Post: 4th May 2008, 08:09 PM
