Results 1 to 7 of 7
10th Jan 2016, 10:36 AM #1Senior Member
- Jan 2016
- Gosford
- 63
- 173
Colt Oxy Acetylene torch extra 'button'?
Having been a metalwork teacher for nearly 25 years I've never came across one of these. I recently bought a load of gear from a deceased estate that contained 2. I had only ever seen and used the CIG Comet type which is the standard industrial blowpipe handle. Apparently the CIG Colt kits are a smaller and light weight torch which I find are actually really nice in the hand. The gear contained 1 torch labelled Colt which is white and one labelled Colt 22 which is blue and even smaller.
Forgive me for asking if this is a stupid question, and I have tried to find out before asking, but what purpose does the button on the back of the hand piece serve? On the Colt the button can be pushed in and slid forward so it locks in place. The Colt 22 button just pushes in and springs back out when released. I had a look inside the hand piece and these buttons are controlling what appears to be a little valve but in operation they appear to do absolutely nothing. Are they superfluous or are the ones on the torches I have not working?
Colt.pngLast edited by glivo; 10th Jan 2016 at 10:45 AM. Reason: Add picture from old Gumtree add
10th Jan 2016, 10:42 AM #2Senior Member
- Oct 2010
- NSW
- 181
They control the oxy cutting stream when you have a cutting tip installed.
10th Jan 2016, 10:44 AM #3
It's for cutting, same as the lever on a Comet torch.
Does nothing with heating tips.
10th Jan 2016, 10:50 AM #4Senior Member
- Jan 2016
- Gosford
- 63
- 173
I considered that but the lever on the Comet cutting attachment is actually on the attachment and controls the oxy flow through the extra tube. This button is on the handpiece itself and when depressed does not appear to add extra oxygen to the flow. I'll have to go and have a closer look. The torches I have did not come with cutting attachments.
10th Jan 2016, 10:54 AM #5
Put a cutting tip on it and it should send oxy through the center hole of the tip.
Won't work with a heating tip.
10th Jan 2016, 10:55 AM #6Senior Member
- Jan 2016
- Gosford
- 63
- 173
I thought this. Thanks.
10th Jan 2016, 04:27 PM #7China
- Dec 2005
- South Australia
- 1,657
In The photo the brass blow pipe is the cutting attachment fit that to the hand piece with a cutting tip and all should work
Extra lathe change gears?
By Greg Q in forum METALWORK GENERALReplies: 16Last Post: 15th May 2011, 09:39 PM -
ASTONISHING PRICES ON MIEBACH-COLT DRILLS, FORSTNERS etc
By FenceFurniture in forum METALWORK GENERALReplies: 0Last Post: 10th Apr 2011, 10:25 AM -
CIG Colt welding tips
By Gavin Newman in forum WELDINGReplies: 3Last Post: 10th Dec 2010, 01:19 PM -
By Gavin Newman in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 6th Dec 2010, 10:04 PM
