Results 1 to 10 of 10
Thread: 16 TPI thread
1st Dec 2015, 02:26 PM #1
16 TPI thread
Hi guys.
i know I asked this question a long time ago but I'm trying to cut an imperial thread 16 tpi
the lathe chart asked for a Z gear and I can't rember which one I used last time
Kim
1st Dec 2015, 02:43 PM #2Most Valued Member
I'm guessing you still have an AL-335?
I assume its metric or you wouldn't need a Z gear
Got a picture of your threading chart?
If its the same as mine
Z gear is 48
24-120-127-48 A2 MII
1st Dec 2015, 03:49 PM #3
Thanks Stuart
I'll give that a go.
Kim
2nd Dec 2015, 02:56 AM #4
Reminds Me again to be thankful for a QCGB.
2nd Dec 2015, 08:12 AM #5Most Valued Member
2nd Dec 2015, 09:23 AM #6Senior Member
- Apr 2013
- Bunbury WA
- 98
I have an AL-336 and the Z is 48, i'm trying to upload a photo of the chart but don't know if it's working.
2nd Dec 2015, 09:26 AM #7Senior Member
- Apr 2013
- Bunbury WA
- 98
From the chart it's a 24-127-48. This lathe is imperial. It's about 3 years old.
2nd Dec 2015, 12:08 PM #8
Thanks Clive.
The job is done and thank you to all who answered.
Kim
2nd Dec 2015, 01:40 PM #9Golden Member
- Cairns, Q
- 666
Yes, but....
I have a modern lathe with QC gearbox. I also have an old 9" lathe which has loose change gears. This is the one I go to for cutting unusual or non-standard thread pitches. It is much more flexible than the modern one for this application. With the help of a few home cut change gears I can cut:
All common Imperial pitches down to 8 tpi including 19 tpi and 27 tpi, but not 11 1/2 tpi.*
All ISO metric pitches from 0.5 to 3.0 to an accuracy of 0.02% pitch error or better*
All common DP threads from 48 to 22 DP to an accuracy of 0.04% pitch error or better*
Good approximations for all 0 BA to 12 BA threads
and various non-standard pitches, so there is still a place for the old lathe with loose change gears.
I have not needed to cut metric module threads yet, but it should be possible.
* Coarser pitch threads in each of the above systems could be cut, but this would mean over driving the lead screw, which I am reluctant to do. If it really became necessary I would probably arrange to drive the lead screw instead of the headstock spindle. It would really be exceeding the design limits of the lathe though.
Frank.
3rd Dec 2015, 04:42 AM #10
I have a Clausing 8000 series that would cut that range of threads, but no mention of accuracy.
Best of the Best thread?
By namtrak in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 7Last Post: 13th Jul 2010, 05:21 PM -
What thread is this?
By neksmerj in forum METALWORK GENERALReplies: 10Last Post: 25th May 2008, 07:29 PM -
This Thread Could Be About You!!!
By sydneyfc in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 2Last Post: 28th Oct 2007, 09:39 PM -
Thread changes?
By oges in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 3Last Post: 20th Nov 2004, 01:12 AM
