Results 1 to 6 of 6
Thread: Bronze Bushes
24th Nov 2015, 04:06 PM #1Member: Blue and white apron brigade
Bronze Bushes
A friend of mine asked me if I would make some replacement bushes for his boat winch.The winch had been adapted from a manual to a 12V powered winch by the removal of the handle and replacing it with a large diameter pulley that is connected to a 12V motor.
Otherwise it’s a standard 3 shaft winch, with 2 pairs of gears winch with the gears locked to the shafts by C-pins
The existing bushes were made of hard black plastic but they have not been able to take the powered load and he has had to replace the bushes twice already and they are starting to need replacing again.
He wanted me to replace the bushes with bearings but there was not enough meat on the winch housing to fit bearings so I suggested using Phosphor Bronze.
A 500 mm long, 26.5 mm OD was the least I could buy from the metal merchant and I started turning these up yesterday.
There are 3 shafts, so 6 bushes, 4 @ 16mm ID and 2 @ 20 mm. The bushes are ~15 mm wide.
The Holes in the galv housing were nominally 24.8mm but were not round and had Galv dribbles inside them - I guess with plastic bushes they are just pushed into the holes and the plastic just flows around any minor irregularities - of course this doesn’t work with bronze.
Just to make things a bit more interesting the bush holes in the housing for the 20 mm shaft were not aligned and had to be squared up.
I started to make each bush specifically to fit each hole but after making the first one I just reamed each hole out to 25mm which made it a bit easier.
One of the shafts is a slider (slides sideways by about 15 mm) which disconnects the gears between cable drum and drive shaft so the cable can be just pulled out manually.
the bushes have a 2mm lip and are inserted into the holes from the inside of the housing so I could not press fit the bronze bushes into the housing holes - so the bronze bushes are just a neat fit into the holes.
On the sliding shaft, instead of the shaft sliding inside the bushes, the bushes themselves were sometimes sliding in their holes which was not good so I managed to drill a 3mm hole and fit a short (7mm) C- pin through the housing into the bush.
The neat thing about this is the pin provides a small oiling hole.
All in all a fiddly job, but lots of glorious coloured swarf everywhere.
Now my mate wants a spare set made !!!!
24th Nov 2015, 06:36 PM #2Pink 10EE owner
- 6,218
Looks good Bob. I generally buy my bronze these days from George Weston & sons.
Contact Us
Had no problems buying over the phone from them.Gold, the colour of choice for the discerning person.
24th Nov 2015, 06:42 PM #3Most Valued Member
Hi Bob,
I think bronze bushes would be the best choice over bearings anyway. I've made a few bronze bushes in recent months. I still get a kick out of making them with just the right amount of clearance. Boy I've stuffed a few up too! I generally get my bush stock from scrap metal. I pay (from memory) $15/Kg which is about a 1/3 of the price of new.
Edit: I can't imagine you will need a spare set of bushes any time soon. They will probably outlast the rest of the winch components!
Nice work!
24th Nov 2015, 07:05 PM #4Member: Blue and white apron brigade
I agree especially given where he takes his boat and trailer.
Nice work!
24th Nov 2015, 10:09 PM #5Most Valued Member
I used to manage a trailer hire place back in the 70's, bronze bushes lasted about 2-3 months, and the cables about 1-2 months, so being an owner user definitely will last a long time. Nice work by the way .
25th Nov 2015, 08:52 PM #6Senior Member
- Apr 2013
- Bunbury WA
- 98
Bob, I see you are in Perth, I get my brass, bronze from Robert Cameron Co in Perth, they are really good to deal with, they don't have a minimum length.
Making Bronze bushes
By simonl in forum METALWORK GENERALReplies: 11Last Post: 7th Aug 2015, 11:36 PM -
Bronze bush. What type of bronze?
By simonl in forum METALWORK GENERALReplies: 23Last Post: 5th Oct 2011, 09:40 PM -
Reducing size of bronze bushes
By JillB in forum METALWORK GENERALReplies: 4Last Post: 26th Jan 2011, 12:16 PM -
worn bronze bushes
By burraboy in forum METALWORK GENERALReplies: 8Last Post: 16th Aug 2007, 07:41 AM
