Results 1 to 8 of 8
10th Nov 2015, 10:19 PM #1Intermediate Member
- May 2013
- Toogoolawah, Queensland
- 66
- 44
Small Quantities Steel Supplier - Brisbane, Ipswich or Caboolture ???
Greetings,
I'm looking to buy a small quantity of 10mm square Mild Steel (or maybe some sort of stainless steel) bar stock to make some carbide tipped Woodturning Tools. A one meter length will give me enough bar stock to make three x approx 300mm long tools. I've got the carbide woodturning cutters on the way from the USA.
Question 1:
I'm looking for a steel supplier in South East Queensland who will supply the small quantity of mild steel that I need. The two places I rang today said that they only sell in minimum orders sizes of $100.
So - does anyone know of a supplier in SEQ that happily sells small quantities ?
Question 2:
I have been considering using some sort of stainless steel (instead of mild steel) for these tools, mainly due to the nasty rust problems I get in this climate. A friend suggest that "stainless" might be too brittle. Is stainless steel to brittle to use in Woodturning Tools ?
As I need to drill and tap the material, I also need to be sure that if I use Stainless Steel, that it will be soft enough to drill and tap.
I'll be grinding the cutting the tool end of the bar stock to take the carbide insert, as well as drilling 5/32" and tapping to take a 10/24 screw. The handle end of the barstock will ground to form a tang to go into a wooden handle.
If stainless steel is feasible for this job, I'll also need to find a supplier for small quantities.
All advice greatly appreciated.
Regards,
RoyGManufacturer of the Finest Quality Swarf.
10th Nov 2015, 11:13 PM #2Intermediate Member
- Jul 2009
- Brisbane
- 48
I just tried to PM you but got the following
"RoyG has exceeded their stored private messages quota and cannot accept further messages until they clear some space."
I have some offcuts of 10 mm square you are welcome to. I have 3 pieces 600mm long but there is probably more if I look a bit harder.
We just need to work out how to get them to you if you are interested.
I live in Bald Hills.
11th Nov 2015, 02:09 AM #3Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,038
I will be buying from Bohler at Wacol in the next week or three. If you are happy with 1214 mild steel I can add your 10 x 10 to my order to get you around the minimum purchase hurdle if that helps. Small sections they only sell by the (6m?) length, if you don't want it all I'd take half, it gets cut in half for the ute.
http://www.buau.com.au/media/BMS.pdf
11th Nov 2015, 07:09 AM #4Golden Member
- Jun 2004
- Kyabram. Vic
- 632
Try a bearing/industrial parts supplier for key steel. Comes in various sized 300mm or so long.
Ken
11th Nov 2015, 08:54 AM #5Senior Member
- Brisbane Australia
- 122
Hi.
Try Bits of Steel in Brendale.
Jim.
11th Nov 2015, 10:41 AM #6Intermediate Member
- May 2013
- 66
- 44
Well ..... thanks for all the suggestions. I should do all right from one of those options.
I notice that nobody mentioned stainless steel in the responses - I gather that's because the idea isn't feasible. So, I guess I'll use mild steel.
Thanks,
11th Nov 2015, 11:45 AM #7
Nothing wrong with using stainless. Depending on the grade it can be a bit harder to drill and tap, but other than that, and perhaps a bit more expensive, no real reason not to use it.
10mm round bar 304 stainless is $9.15 per meter.
All Things Stainless Steel - All Things Stainless Steel
11th Nov 2015, 11:47 AM #8Banned
- Aug 2015
- QLD
- 735
RoyG, there's an engineering shop in Toogoolahwah. Why don't you try him for some off-cuts.
Supplier of high speed steel and tool steel bar and spring steel in melbourne?
By fudo133 in forum METALWORK GENERALReplies: 3Last Post: 25th Jun 2014, 12:44 PM -
Looking for a Metal Worker in SW Brisbane for small turning job
By skot in forum METALWORK GENERALReplies: 8Last Post: 28th Sep 2013, 06:52 PM -
Steel Suppliers Brisbane
By smidsy in forum METALWORK GENERALReplies: 4Last Post: 15th Mar 2012, 03:10 PM -
Online supplier of small screws
By snowyskiesau in forum METALWORK GENERALReplies: 26Last Post: 20th Sep 2010, 03:00 PM -
Found Great Steel Supplier for Small Guy
By Watts2759 in forum WELDINGReplies: 13Last Post: 6th Jul 2008, 09:29 PM
