Results 1 to 12 of 12
Thread: Lathe felt
8th Aug 2015, 12:14 PM #1Senior Member
- Feb 2012
- Willunga
- 114
Lathe felt
I am doing a cleanup and refurb on my Lantain Lathe, now 37 years old! One of the things that I would like to do is replace the felt wipers on the carriage. Does anyone know what sort of felt should go there and where I might be able to get some?
Ian
8th Aug 2015, 12:33 PM #2.
- 6,459
Have a look here Ian - http://www.feltsales.com.au/
BT
edit. or here - http://www.ebay.com.au/itm/Engineeri...item19ddbeef7eLast edited by Anorak Bob; 8th Aug 2015 at 12:37 PM. Reason: found something easier
8th Aug 2015, 01:21 PM #3New Member
- May 2015
- 7
You can buy the felt in different size square profile at most bearing companies. They use the same felt in self aligning bearing blocks.
8th Aug 2015, 04:28 PM #4Senior Member
- Feb 2012
- Willunga
- 114
Thanks very much Bob and SB, I will chase some up. Its much easier when you know what it is called!
Ian
8th Aug 2015, 04:43 PM #5Novice
- Jul 2008
- Northcote, VIC
- 19
Is the quality of the felt important for wipers? I went to Spotlight and got some heavy duty felt of the correct thickness and cut the wipers for my Hercus ARM by hand.
Is it going to explode? They only wipe oil on the ways...
Martin
8th Aug 2015, 05:02 PM #6Banned
- Jul 2011
- Melbourne Australia
- 1,376
I'm pretty sure I can recall Steamwispherer Phil, mentioning buying felt from Spotlight, for some thing they do at Sovereign hill.
If they look and seem to be doing the job, it must be right.
Regards Phil.
8th Aug 2015, 05:44 PM #7Philomath in training
This one may be closer -
Felt Fabricating Pty Ltd
Unit 10, 5 Tooronga Ave
Edwardstown, S.Aust 5039
Ph: (08) 8374 1429Fax: (08) 8374 0244email: [email protected]
If you only need a little bit I have some 1/4" thick stuff I can give you.
8th Aug 2015, 07:47 PM #8Cba
- Aug 2007
- 68
- 1,410
If you have an old Akubra hat... its excellent very high density felt and cuts easily without fraying out. You have to cut 3 or 4 pieces and double them up to the required thickness. Use a punch if it needs holes for mounting. Spotlight has some thick felt too, but its a much less dense quality that tends to fray out when cutting. It still works as wiper when compressed by the mounting plate. If you need a small amount of about 5mm thick, high quality dense felt try a filter insert for Stihl wipper snippers - cheaper than to buy industrial felt sold by the meter.
8th Aug 2015, 08:42 PM #9Senior Member
- Feb 2012
- Willunga
- 114
Thanks Michael, I have to go to the airport on Monday and I will try that crowd.
Ian
10th Aug 2015, 09:12 AM #10Most Valued Member
- 4,258
10th Aug 2015, 11:23 PM #11Banned
- Jul 2011
- 1,376
I've always had it that you need the type A engineered hard felt, for wipers. No idea where I got that from. Folklore probably. It just hangs in my mind.
Phil.
11th Aug 2015, 10:01 AM #12
Isn't there the possibility of some of the synthetic felts picked up at spotlight etc breaking down in contact with the oil??
Proper machine felt and natural fibre felt would be impervious.…..Live a Quiet Life & Work with your Hands
Felt for Lathe Way wipes
By argeng in forum METALWORK GENERALReplies: 9Last Post: 2nd Jun 2013, 11:11 AM -
Engineering Felt
By Lanza_1 in forum METALWORK GENERALReplies: 8Last Post: 7th Nov 2009, 09:51 PM
